Upload to SSA does not work, but the dmx encoder does
usb to dmx - 19'' rack - 16 flash buttons - dmx input (2003 - 2010)
marijnboeve
Post by marijnboeve »
I have multiple SSA units, not 1 of them i get the stand alone to work. The encoder does work en the software sees the controller, when i make a simple step and place it on the timeline when selecting a button and zone it does upload, i dont get a windows but the lights flashes. but it will not work when i press te button. when i enable the dmx output in the standalone windows en press play in a button i see the lights change like it would need to be.
Im on Macos 26.5 ( but have tried it in the past on win 10 and 11 pc and it didnt work ether)
Software is on 9.2.23
See images and show file in link.
https://we.tl/t-YoF36EiCU5sxmnad
Re: Upload to SSA does not work, but the dmx encoder does
Thank you for the detailed information.
The SSA is a very old interface (year 2003). While it is still supported by the current software for live control from a computer, the standalone programming features are no longer fully compatible with recent software versions.
From your description, the hardware communication appears to be working correctly, as the software detects the interface, the encoder responds, and DMX output can be triggered from the software. This suggests that the issue is related to the standalone programming compatibility rather than a hardware fault.
To use the standalone mode of the SSA interface, you will need to use an older version of the software from the period when the SSA was actively supported for standalone operation.
https://forum.thelightingcontroller.com ... php?t=4553
The version 8 should be ok.
If not, please try the version 7.
marijnboeve
Thanks for the reply.
I managed to get it working in the end by using an older version of the software. In my case, I used a Windows 11 laptop, installed SweetLight version 5, and also installed the old USB-DMX drivers.
During the driver installation, Windows blocked the driver because of driver signature enforcement. I solved this by opening Command Prompt as Administrator and running:
bcdedit -set loadoptions DDISABLE_INTEGRITY_CHECKS
After restarting the laptop, I installed the DMX-to-USB driver manually through Device Manager.
After that, I was able to program the standalone buttons on the SSA successfully.
Hope this helps anyone else with the same problem!
Thank you for sharing this information and for taking the time to explain the procedure.
You have indeed followed the correct process to get the SSA working with older hardware and software versions.
Unfortunately, this procedure requires modifying Windows security settings and manually installing legacy drivers, which makes it unsuitable for most users. For this reason, we cannot officially recommend or document it as a standard solution.
Nevertheless, your feedback may be very useful for experienced users who are trying to keep older SSA interfaces operational.
Thank you again for sharing your findings.
Return to “Ssa”
