Midi In Problem
socalmagic
Midi In Problem
Post by socalmagic »
Hello, I'm trying to send a Midi message from a theater cueing program (Multiplay) to ShowXpress, but it isn't working. I tried learn, and it doesn't get the message. Multiplay has a 2nd field for Data 2, but I don't see that in ShowXpress. Not sure if that's causing the problem. I do have a virtual cable set-up and it's showing up in ShowXpress as working. Please advise.
Multiplay Midi.png (20.65 KiB) Viewed 18278 times
Re: Midi In Problem
Can you please open the window "Midi logger" (main menu "Windows" > "Midi logger") and tell us the incoming midi messages.
socalmagic
Re: Midi In Problem
Here's a screenshot. It will only trigger when I have it set to Program, and not control or note.
Screenshot 2025-10-10 151456.png (9.25 KiB) Viewed 18270 times
Re: Midi In Problem
Noted.
So if we right understand, it works ok when you set the trigger type to "Program" (?)
This is odd but if it works like this, please go for the selection "Program".
