When placing an object and changing the scale manually, the software, for some reason makes x10 the scale you entered previously.
Small bug, seems like a simple fix.
Current version used: 9.3.16
Thanks!
Problem entering values for "Scale" parameter in feets [fixed]
Re: Software bug in "3d view"
We are not able to reproduce that.
Could you please post a video showing that ?
Sure!
I'm not great at videos, but here what I made:
http://piobee.com/extra/20241129_173440.mp4
Hope this explains better
Edit: also, the show on this video is just a rough right now, Yes, more fixtures will be added; and yes, I know current adressing don't really make sense ricght now. I promise it will be fixed before making the actual scenes
Thank you for this video.
We clearly see the problem.
But we do same as you here and it works ok with us !
We are trying to understand why this happen on your PC.
We presently have no idea and we are looking for a track to investigate.
Re: Problem entering values for "Scale" parameter
We have seen the problem. This happens when lengths in feet are used.
We are looking at how to fix this...
Fixed for next fix file.
The fix file is available.
