After applying Fix file - Wont start up
Cablecr69
Post by Cablecr69 »
I am running 9.3.9. When I download the latest fix file and apply the software no longer will open.
Im apply the library file and the English ini file.
I will be trying VII on my M1 soon but still want a stable one on my other Mac.
Thanks,
Chris
Re: After applying Fix file - Wont start up
Please post a link to download a zip of your lightshow.
We will check that.
Cablecr69
Post by Cablecr69 »
Hello Support,
https://drive.google.com/drive/folders/ ... sp=sharing
Here is a link to the show file with music and a zipped version without.
Thanks,
Chris
The ZIP file contains our software. This is not what we need. We need the lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168).
We have your WAV files.
Cablecr69
Post by Cablecr69 »
I have exported the lightshow and added it to the google drive under folder DSUK.
This is from the version that is working as when I apply the fix...it will not load.
No problem with your lightshow and the latest version of our software here.
https://ibb.co/Ms3fqYV
Could you please send the file "param.ini" which is one level above your lightshow folder.
(the path is ".../home_directory/TheLightingController/param.ini")
Cablecr69
Post by Cablecr69 »
Here is the file.
param.ini
(297 Bytes) Downloaded 570 times
We do not see any problem in this file, either.
Could you please try with the latest fix for V9.3.14 (https://forum.thelightingcontroller.com ... =85&t=3438) and let us know ?
Cablecr69
Post by Cablecr69 »
Same problem.
This is apple crash report.
Process: TheLightingController [3730]
Path: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [3730]
User ID: 502
Date/Time: 2024-05-06 22:51:04.493 +0100
OS Version: Mac OS X 10.13.6 (17G14042)
Report Version: 12
Anonymous UUID: 0F1464C6-BA5E-8201-B2FE-0C6CF50C4532
Sleep/Wake UUID: 4094B723-BCF9-4D5E-8B31-DDD844D1B2F1
Time Awake Since Boot: 7200 seconds
Time Since Wake: 3700 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x4] Symbol missing
Dyld Error Message:
Symbol not found: ____chkstk_darwin
Referenced from: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Expected in: /usr/lib/libSystem.B.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 dyld 0x000000010d28d256 __abort_with_payload + 10
1 dyld 0x000000010d28cbc8 abort_with_payload_wrapper_internal + 89
2 dyld 0x000000010d28cbf5 abort_with_payload + 9
3 dyld 0x000000010d260482 dyld::halt(char const*) + 354
4 dyld 0x000000010d2605a9 dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 170
5 libdyld.dylib 0x00007fff56331292 dyld_stub_binder + 282
6 ??? 0x0000000104ecac30 0 + 4377586736
7 libdyld.dylib 0x00007fff56331015 start + 1
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000002000209 rbx: 0x0000000000000004 rcx: 0x00007ffeeb00f9b8 rdx: 0x00007ffeeb00fe30
rdi: 0x0000000000000006 rsi: 0x0000000000000004 rbp: 0x00007ffeeb00fa10 rsp: 0x00007ffeeb00f9b8
r8: 0x00007ffeeb00fa30 r9: 0x0000000000000000 r10: 0x00000000000000b0 r11: 0x0000000000000246
r12: 0x00000000000000b0 r13: 0x00007ffeeb00fe30 r14: 0x0000000000000006 r15: 0x0000000000000000
rip: 0x000000010d28d256 rfl: 0x0000000000000246 cr2: 0x000000010d2ddfe0
Logical CPU: 0
Error Code: 0x02000209
Trap Number: 133
Binary Images:
0x104bef000 - 0x104eb2ff7 +TheLightingController (0.1) <81E0D438-83C0-389D-9FD7-94215E83B8C3> /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x10d25c000 - 0x10d2a6adf dyld (551.5) <CB9BFB56-4511-36F1-A546-891FF770C01C> /usr/lib/dyld
0x7fff2a3cf000 - 0x7fff2a5afff3 com.apple.avfoundation (2.0 - 1536.36) <AB868021-AB26-3198-897D-087EF3B360EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff2a5b0000 - 0x7fff2a669fff com.apple.audio.AVFAudio (1.0 - ???) <716306C4-A0EA-3D81-8F33-943153538C47> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff2a66b000 - 0x7fff2a76efff com.apple.AVKit (1.1 - 440.10) <F684B2B0-4C97-3AD2-AFFE-B6561175621C> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fff2a76f000 - 0x7fff2a76ffff com.apple.Accelerate (1.11 - Accelerate 1.11) <8632A9C5-19EA-3FD7-A44D-80765CC9C540> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2a787000 - 0x7fff2ac85fc3 com.apple.vImage (8.1 - ???) <A243A7EF-0C8E-3A9A-AA38-44AFD7507F00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2ac86000 - 0x7fff2ade0fe3 libBLAS.dylib (1211.50.2) <62C659EB-3E32-3B5F-83BF-79F5DF30D5CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2ade1000 - 0x7fff2ae0ffef libBNNS.dylib (38.1) <7BAEFDCA-3227-3E07-80D8-59B6370B89C6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2ae10000 - 0x7fff2b1cfff7 libLAPACK.dylib (1211.50.2) <40ADBA5F-8B2D-30AC-A7AD-7B17C37EE52D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2b1d0000 - 0x7fff2b1e5ff7 libLinearAlgebra.dylib (1211.50.2) <E8E0B7FD-A0B7-31E5-AF01-81781F71EBBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2b1e6000 - 0x7fff2b1ebff3 libQuadrature.dylib (3) <E936BDAF-8492-34D9-8C5C-AFBFCDAD8318> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2b1ec000 - 0x7fff2b26cfff libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2b26d000 - 0x7fff2b280fff libSparseBLAS.dylib (1211.50.2) <722573CC-31CC-34B2-9032-E4F652A9CCFE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2b281000 - 0x7fff2b42efc3 libvDSP.dylib (622.50.5) <40690941-CF89-3F90-A0AC-A4D200744A5D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2b42f000 - 0x7fff2b4e0fff libvMisc.dylib (622.50.5) <BA2532DF-2D68-3DD0-9B59-D434BF702AA4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2b4e1000 - 0x7fff2b4e1fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <54FF3B43-E66C-3F36-B34B-A2B3B0A36502> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2b7d5000 - 0x7fff2c633fff com.apple.AppKit (6.9 - 1561.61.100) <4E6EA3FA-8C2C-3B21-BFF9-6F8C458B7BE1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2c685000 - 0x7fff2c685fff com.apple.ApplicationServices (48 - 50) <2B5B76E7-0AB2-31F9-BE58-B963BF1EC2E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2c686000 - 0x7fff2c6ecfff com.apple.ApplicationServices.ATS (377 - 445.5) <60176327-F757-308E-B61A-D43394E87CC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2c785000 - 0x7fff2c8a7ff7 libFontParser.dylib (222.1.9) <FFF2AC1A-D4D2-3AD3-BFF2-F3649ECB02AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff2c8a8000 - 0x7fff2c8f3ff7 libFontRegistry.dylib (221.6) <30C6D1DE-C0E3-3447-A0EF-829443D95F0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2ca35000 - 0x7fff2ca39ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <04764FB2-22D8-36F0-9647-2D21562E28D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2cad9000 - 0x7fff2cb2bffb com.apple.HIServices (1.22 - 625) <3C059A55-1409-373E-BF0B-C3299AFABDCF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2cb2c000 - 0x7fff2cb3afff com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BB267F4-D5AA-3D35-8269-1A3CEA054ACD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2cb3b000 - 0x7fff2cb87fff com.apple.print.framework.PrintCore (13.4 - 503.2) <2EA98448-9D6A-3912-9933-F7703CB01B6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2cb88000 - 0x7fff2cbc2fff com.apple.QD (3.12 - 404.2) <525E9518-DFF3-3D8D-BD48-E0D63EEDBD16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2cbc3000 - 0x7fff2cbcffff com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) <CD09019C-569B-3A56-B84C-26F2A6223455> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2cbd0000 - 0x7fff2ce5eff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <C7BE1645-BE23-3427-8650-1CEFDAF86710> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2ce60000 - 0x7fff2ce60fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <294802B9-E24D-34EB-973F-6D2B8E2E86CB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2d183000 - 0x7fff2d520fff com.apple.CFNetwork (902.6 - 902.6) <46168F79-CCFA-349A-8508-B8CBCE27D440> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2d535000 - 0x7fff2d535fff com.apple.Carbon (158 - 158) <F8B370D9-2103-3276-821D-ACC756167F86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff2d536000 - 0x7fff2d539ffb com.apple.CommonPanels (1.2.6 - 98) <075486A5-8E39-3F72-BED7-752517379C55> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff2d53a000 - 0x7fff2d83ffff com.apple.HIToolbox (2.1.1 - 911.10) <8D2EBE85-9AF0-38BC-ACD3-1ED978643907> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2d840000 - 0x7fff2d843ffb com.apple.help (1.3.8 - 66) <7F210C1C-D7D3-3C97-A2E4-D3CC35F91807> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff2d844000 - 0x7fff2d849fff com.apple.ImageCapture (9.0 - 9.0) <3993E094-AB86-3B22-BC18-4550F23854FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff2d84a000 - 0x7fff2d8dfffb com.apple.ink.framework (10.9 - 221) <83976BB8-A423-3AA5-8221-6EB04B3DEF0A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2d8e0000 - 0x7fff2d8faff7 com.apple.openscripting (1.7 - 174) <C282DFBB-4BF2-3222-87E0-0B560D5B4B2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff2d91b000 - 0x7fff2d91cfff com.apple.print.framework.Print (12 - 267) <DFC4CE94-F6E6-3DFA-AB88-A13E4C5A7701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff2d91d000 - 0x7fff2d91fff7 com.apple.securityhi (9.0 - 55006) <1AB48F32-D1CB-3657-A30C-40A7E718A71D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff2d920000 - 0x7fff2d926fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A07BB54-438B-34C9-8061-45403E197ACA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2da47000 - 0x7fff2da47fff com.apple.Cocoa (6.11 - 22) <3269BC26-0217-39FE-A600-D702656D838B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff2da55000 - 0x7fff2db0efff com.apple.ColorSync (4.13.0 - 3325) <EAD2D314-E810-33FB-B105-BD30ABB912AD> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff2dc9b000 - 0x7fff2dd2eff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF2B41CC-DD7A-34EB-A842-00DC3B8F2E9F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2dd95000 - 0x7fff2ddbeffb com.apple.CoreBluetooth (1.0 - 1) <ED48840B-A80A-32C1-8E4B-DEB7A7CD3C1A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff2ddbf000 - 0x7fff2e115fef com.apple.CoreData (120 - 851) <7361F2EA-2B7F-3259-909F-287BEB443781> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff2e116000 - 0x7fff2e1f9fff com.apple.CoreDisplay (99.14 - 99.14) <9B2B211D-EC0A-3569-BB37-887768CD6105> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2e1fa000 - 0x7fff2e69dfe7 com.apple.CoreFoundation (6.9 - 1455.300) <CB44B892-64CD-3E32-A518-6D40B1A7033F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2e69f000 - 0x7fff2ecaffef com.apple.CoreGraphics (2.0 - 1161.21.5) <6451A561-3A83-37FB-AAA7-3FCE6D95C34C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff2ecb1000 - 0x7fff2efa0fff com.apple.CoreImage (13.0.0 - 579.5) <B2B60A80-2E10-3EDF-920C-94288E55AE25> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff2f00d000 - 0x7fff2f052fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <EE9A1F14-93BB-3DB1-AD62-064C1F4B6D85> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff2f22f000 - 0x7fff2f325ffb com.apple.CoreMedia (1.0 - 2276.80.4) <67942D16-3658-37FC-B61C-8ED3D4BFBFB9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff2f326000 - 0x7fff2f374fff com.apple.CoreMediaIO (814.0 - 4995) <2A174DD1-431A-3313-9837-04C7E1B284B6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff2f375000 - 0x7fff2f375fff com.apple.CoreServices (822.37 - 822.37) <CE816EF2-2B89-3F54-A5C6-D3080B1EFB00> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff2f376000 - 0x7fff2f3eaffb com.apple.AE (735.2 - 735.2) <0938A72B-6A4A-36F1-95B3-5EF6B915CEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff2f3eb000 - 0x7fff2f6c2fff com.apple.CoreServices.CarbonCore (1178.4.2 - 1178.4.2) <4692EE3A-11FE-31FD-AF5B-30F892E87A05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff2f6c3000 - 0x7fff2f6f7fff com.apple.DictionaryServices (1.2 - 284.2) <F1F3EFAE-2562-394D-8FB3-BE22F16CD75A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2f6f8000 - 0x7fff2f700ffb com.apple.CoreServices.FSEvents (1239.50.2 - 1239.50.2) <FE465894-4235-3CE2-9A97-32D6C6C7D9AD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2f701000 - 0x7fff2f8bfff7 com.apple.LaunchServices (822.37 - 822.37) <0DB4679F-AE39-3BF3-B39B-549322E355AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff2f8c0000 - 0x7fff2f970fff com.apple.Metadata (10.7.0 - 1191.8) <F3BD3FD7-208A-31E9-85CD-6E607DDAFEF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2f971000 - 0x7fff2f9d1fff com.apple.CoreServices.OSServices (822.37 - 822.37) <564DDE70-0250-346B-B5CC-4AFAC11A7373> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2f9d2000 - 0x7fff2fa40fff com.apple.SearchKit (1.4.0 - 1.4.0) <97DD9E7D-3567-382B-ACF7-CE0E4FE78D36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2fa41000 - 0x7fff2fa65ffb com.apple.coreservices.SharedFileList (71.21 - 71.21) <88991F51-0A75-34FF-8C91-ED0F3C270B7B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff2fd06000 - 0x7fff2fe56fff com.apple.CoreText (352.0 - 578.23) <10DAF601-85A8-3F9C-8B0B-69DC16B95E47> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff2fe57000 - 0x7fff2fe91fff com.apple.CoreVideo (1.8 - 0.0) <0DD4FFDF-E1F1-39D1-8246-5D0D9869F1EA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff2fe92000 - 0x7fff2ff1dff3 com.apple.framework.CoreWLAN (13.0 - 1350.2) <EC145FBD-F638-38B8-BE94-F892A2F02550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff30198000 - 0x7fff3019dfff com.apple.DiskArbitration (2.7 - 2.7) <51DC4AED-6F0C-321F-93E3-20EA4341B768> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3035e000 - 0x7fff30725ffb com.apple.Foundation (6.9 - 1455.300) <0479E072-1DD0-3881-A9A2-EDAD3EE58C23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff30796000 - 0x7fff307c6ff3 com.apple.GSS (4.0 - 2.0) <7E83A21E-4F90-38F3-9FD3-FAC0E0143243> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff308d8000 - 0x7fff309dcffb com.apple.Bluetooth (6.0.7 - 6.0.7f22) <08E33A6B-16A7-3E4E-82C9-E1E5A84300D0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff30a3c000 - 0x7fff30ad7fff com.apple.framework.IOKit (2.0.2 - 1445.71.6) <4B5C715C-6A49-366B-9080-ABADE6A3B3BD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff30ad9000 - 0x7fff30ae0fff com.apple.IOSurface (211.15 - 211.15) <08DA3232-805F-304B-80DD-C86B49CC4AAD> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff30b37000 - 0x7fff30cb2fe7 com.apple.ImageIO.framework (3.3.0 - 1739.3.8) <58BD6865-E629-3283-859B-82C4C3A5FF66> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff30cb3000 - 0x7fff30cb7ffb libGIF.dylib (1739.3.8) <E3446976-10BF-3B75-9A11-32893368D748> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff30cb8000 - 0x7fff30d9ffe7 libJP2.dylib (1739.3.8) <4B440B09-1542-304C-8BE5-EB0F9370046C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff30da0000 - 0x7fff30dc3ff7 libJPEG.dylib (1739.3.8) <F6BCF3DA-6F0B-35A8-982C-BEFD2DD6DBFE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff310b2000 - 0x7fff310d8feb libPng.dylib (1739.3.8) <25C5D4B1-3715-3DF5-BE4B-C71089ADBBFE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff310d9000 - 0x7fff310dbffb libRadiance.dylib (1739.3.8) <5134034F-A7BC-3749-A141-92BC89579AF6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff310dc000 - 0x7fff3112afe7 libTIFF.dylib (1739.3.8) <91F6CDBD-C4A0-3614-81DC-B9A9E3838CF0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff31fe4000 - 0x7fff31ffdff7 com.apple.Kerberos (3.0 - 1) <C7CDC1E0-011B-3220-847D-1AC3DA6D5522> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff322bc000 - 0x7fff322c3fff com.apple.MediaAccessibility (1.0 - 114) <00F21329-1163-3283-A882-A5DD7A12D353> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff322d9000 - 0x7fff32372fff com.apple.MediaPlayer (1.0 - 1.0) <E04A1D72-429F-390E-9542-0DEB46DFB3EA> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
0x7fff32373000 - 0x7fff329ddff7 com.apple.MediaToolbox (1.0 - 2276.80.4) <FA444376-E5AF-36AB-BE1D-76ECE4D72049> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff329df000 - 0x7fff32a60fff com.apple.Metal (125.30 - 125.30) <67EDA241-80B1-3C67-BB2B-FF83E49FEF8D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff32a7d000 - 0x7fff32a98fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <8DED0F0C-4A10-36A3-A3E2-7D3CF429ACE1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff32a99000 - 0x7fff32b08fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <48F4A97F-143A-3918-AB92-6733E258E25A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff32b09000 - 0x7fff32b2dfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <CD443ADC-07FE-3603-B0C9-60C2AF3616FF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff32b2e000 - 0x7fff32c15ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <40EB0BAE-6DDE-3334-A28C-529AE4C6716A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff32c16000 - 0x7fff32c16ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <A111E862-43E5-3247-9E98-0A40DC34AD9B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff33c15000 - 0x7fff33c21ffb com.apple.NetFS (6.0 - 4.0) <02E09301-324F-3542-875D-B87B144635C8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff36a13000 - 0x7fff36a6dff7 com.apple.opencl (2.8.24 - 2.8.24) <429B5283-276D-372D-BB0E-EEBE1408C393> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff36a6e000 - 0x7fff36a8affb com.apple.CFOpenDirectory (10.13 - 207.50.1) <E9AD4934-5DE3-3DD0-9D7B-9D288D829F15> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff36a8b000 - 0x7fff36a96fff com.apple.OpenDirectory (10.13 - 207.50.1) <8B54C486-14C9-3FEF-97B8-F4D6F59F75CF> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff37c15000 - 0x7fff37c17fff libCVMSPluginSupport.dylib (16.7.4) <3E26CF2B-5074-3321-AD9E-6A667D61AA35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff37c18000 - 0x7fff37c1dffb libCoreFSCache.dylib (162.12) <D12E1D0E-C0E5-329E-99B4-AB152C9ABBE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff37c1e000 - 0x7fff37c22fff libCoreVMClient.dylib (162.12) <39951906-8566-3F9D-9EA8-EBD6084DCF73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff37c23000 - 0x7fff37c2cff3 libGFXShared.dylib (16.7.4) <81A7875B-103D-3C82-B25C-DE24E57E5C8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff37c2d000 - 0x7fff37c38fff libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff37c39000 - 0x7fff37c74fe7 libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff37de3000 - 0x7fff37e21ffb libGLU.dylib (16.7.4) <BCB09CD8-EB0E-38FA-8B5A-9E29532EE364> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff38799000 - 0x7fff387a8ff3 com.apple.opengl (16.7.4 - 16.7.4) <77A788F3-8F0C-305C-AEB9-FF258676C599> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff38b27000 - 0x7fff38c73ff7 com.apple.QTKit (7.7.3 - 3014.8) <F333568C-D990-3BBA-A09B-ABAB5F984905> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff395fc000 - 0x7fff39848ff7 com.apple.QuartzCore (1.11 - 584.64.2) <FD9A3180-479E-3DAC-9CF0-0D214C7E46A7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3a080000 - 0x7fff3a3abfff com.apple.security (7.0 - 58286.70.19) <E118FC23-2E20-3999-826B-58488049A277> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3a3ac000 - 0x7fff3a438ff7 com.apple.securityfoundation (6.0 - 55185.50.5) <3D9AD4EF-439C-3AE1-9332-AD291CF96C64> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3a46a000 - 0x7fff3a46effb com.apple.xpc.ServiceManagement (1.0 - 1) <3FCAF325-40C8-3148-9E49-E555F95B2946> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3a813000 - 0x7fff3a883ff3 com.apple.SystemConfiguration (1.17 - 1.17) <41D509AB-AED3-30FF-BB00-615BB5A8AC00> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3aa38000 - 0x7fff3adb3fff com.apple.VideoToolbox (1.0 - 2276.80.4) <1C94A509-0372-3B58-94BC-4488C042BD79> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff3d780000 - 0x7fff3d813ff3 com.apple.APFS (1.0 - 1) <70034B32-9347-30FB-9DDE-95061F686613> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff3e41f000 - 0x7fff3e447fff com.apple.framework.Apple80211 (13.0 - 1370.4) <C296CDDB-0A79-3D6B-898A-0FBA1892F5AC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff3e449000 - 0x7fff3e458fef com.apple.AppleFSCompression (96.60.1 - 1.0) <CBE1A092-CE90-36B9-AAA6-0BE2E7921504> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff3e557000 - 0x7fff3e562ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <924EA55F-1C87-347F-9212-F79EA2B2C84C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff3e59c000 - 0x7fff3e5e4ff3 com.apple.AppleJPEG (1.0 - 1) <15558577-08E3-3087-86A9-8B6247978BCE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff3e61f000 - 0x7fff3e647fff com.apple.applesauce (1.0 - ???) <9CE4CAE2-30B9-3DF6-9BC0-33D532D7B937> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff3e714000 - 0x7fff3e764ff7 com.apple.AppleVAFramework (5.0.41 - 5.0.41) <C82921AA-1537-3736-BC16-5CABB3EF0100> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff3ea9a000 - 0x7fff3ed33ffb com.apple.AuthKit (1.0 - 1) <C3087797-E472-300E-8B4A-448857ACE8E7> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff3ee6a000 - 0x7fff3ee71ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <B2A1EEDF-490A-38E2-A896-41057C0417BF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff3ee72000 - 0x7fff3eef9ff7 com.apple.backup.framework (1.9.6 - 1.9.6) <0A54D219-E71B-3BC6-8DFC-11ED47E431BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff408b5000 - 0x7fff408beff3 com.apple.CommonAuth (4.0 - 2.0) <21AF4AC2-E650-35F9-AB33-3EBA2769FBC0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff40bfa000 - 0x7fff41002fff com.apple.CoreAUC (259.0.0 - 259.0.0) <EF95ED0E-F4F1-3969-89BB-CE8CDD74C29F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff41003000 - 0x7fff41033ff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <6AC79B1F-0A12-34A4-BC0D-5A6A65ABABE0> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff413d2000 - 0x7fff413e2ff7 com.apple.CoreEmoji (1.0 - 69.3) <DCCF04BB-DA33-3DC0-B7C2-1D34870C0C0A> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff416e6000 - 0x7fff416fcff7 com.apple.CoreMediaAuthoring (2.2 - 956) <EE44B61D-6742-3649-A52F-C6AA0431F846> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff41b76000 - 0x7fff41b7eff3 com.apple.CorePhoneNumbers (1.0 - 1) <3B388768-5CDB-341A-BCE2-4047EAD009EA> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff420b4000 - 0x7fff42145fff com.apple.CoreSymbolication (9.3 - 64026.2) <30652FA5-C731-3A22-864D-DF6D9C77CD4C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff421c8000 - 0x7fff422fdfff com.apple.coreui (2.1 - 494.1) <5B4F3E9C-A4EF-3908-A035-59B8631C3685> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff422fe000 - 0x7fff4242ffff com.apple.CoreUtils (5.6 - 560.11) <2C5A0610-1F08-3603-8692-EE03E62EE622> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff42484000 - 0x7fff424e8fff com.apple.framework.CoreWiFi (13.0 - 1350.2) <500CC54F-A6CB-3D36-9BB1-C9C9F6A6E414> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff424e9000 - 0x7fff424f9ff7 com.apple.CrashReporterSupport (10.13 - 1) <1ADEC140-4838-3976-A14B-6268C5251481> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff42578000 - 0x7fff42587ff7 com.apple.framework.DFRFoundation (1.0 - 191.7) <F7AB1B29-A4B0-3938-AFDC-DAA204929404> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4258a000 - 0x7fff4258effb com.apple.DSExternalDisplay (3.1 - 380) <13AA3B17-E649-3B7B-B09D-9AE7C4A60887> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff42610000 - 0x7fff42686fff com.apple.datadetectorscore (7.0 - 590.3) <E645FBF0-B47D-3394-84DF-792B85E94CB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff426d4000 - 0x7fff42714ff7 com.apple.DebugSymbols (181.0 - 181.0) <702DB951-F5A6-3155-9D84-BBA9A4B4E1BD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff42715000 - 0x7fff42844fff com.apple.desktopservices (1.12.5 - 1.12.5) <96BB57E2-3359-3920-AA7C-BF03C2225485> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff43659000 - 0x7fff43a87fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <06065DA3-4091-3682-A308-BF3F2E3E4AF8> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff46d4f000 - 0x7fff46d54fff com.apple.GPUWrangler (3.20.18 - 3.20.18) <B54A9063-01EC-3D2C-8924-86A1F315DEA2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff47aca000 - 0x7fff47ad9fff com.apple.GraphVisualizer (1.0 - 5) <EB42FFAD-2BCA-3DE2-B40E-AFDE6E7FAA4D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff47b5c000 - 0x7fff47bd0fff com.apple.Heimdal (4.0 - 2.0) <FF7BC1AE-1BA6-3150-A7CC-B9E0AD5EBE7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff484e3000 - 0x7fff484eaff7 com.apple.IOAccelerator (378.28 - 378.28) <F109E4CB-49D9-37FB-974A-8A3E9E8A61DA> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff484ee000 - 0x7fff48505fff com.apple.IOPresentment (1.0 - 35.1) <AC89202B-8433-3B62-A7BE-467D1905F6FB> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff488d0000 - 0x7fff488f6ffb com.apple.IconServices (97.6 - 97.6) <7913A453-8D29-31DC-ADDB-7CEC068C9B86> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff48a03000 - 0x7fff48a06ff3 com.apple.InternationalSupport (1.0 - 1) <D020C355-DCC1-3D7E-8FCE-BD6FF441824D> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff48a74000 - 0x7fff48a84ffb com.apple.IntlPreferences (2.0 - 227.5.2) <E036B12B-6017-3EF6-9E73-71DCE8036608> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff48b7b000 - 0x7fff48b8eff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <B999BEF6-F3E7-30EE-9177-FBC8E826659D> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff48b8f000 - 0x7fff48c84ff7 com.apple.LanguageModeling (1.0 - 159.5.3) <FAA236D6-CFB8-37D2-B635-B324E0719E32> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff48c85000 - 0x7fff48cc7fff com.apple.Lexicon-framework (1.0 - 33.5) <F8DD2D09-5CEE-3741-93CF-223FC61FCCA4> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff48ccb000 - 0x7fff48cd2ff7 com.apple.LinguisticData (1.0 - 238.3) <6F2ED02A-2120-3ABA-8EC1-314E4FFE77F3> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff494d3000 - 0x7fff494d6fff com.apple.Mangrove (1.0 - 1) <471F4581-5235-3381-B16B-CE92ED6CF086> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff49626000 - 0x7fff4994fff7 com.apple.MediaRemote (1.0 - 1) <1FE6F7B0-E949-36F3-9646-1B85BA1BAF20> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff49950000 - 0x7fff49971fff com.apple.MediaServices (1.0 - 1) <7AE9BD6D-594B-319E-A750-D0607150BAE1> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff499e6000 - 0x7fff49a4fff7 com.apple.gpusw.MetalTools (1.0 - 1) <F2A47319-0430-3BB5-943E-651A40C127A9> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff49d58000 - 0x7fff49d71fff com.apple.MobileKeyBag (2.0 - 1.0) <9EA31672-3B83-3ABF-B2D5-8584E159051E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff49dfd000 - 0x7fff49e27ffb com.apple.MultitouchSupport.framework (1614.1 - 1614.1) <A376F2FB-64AE-3B35-88B0-7D2BB4D1CB7C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff4a08e000 - 0x7fff4a099fff com.apple.NetAuth (6.2 - 6.2) <85C5D94D-C67E-36DC-B0EA-02F53AC4FCD3> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff4b935000 - 0x7fff4b945ffb com.apple.PerformanceAnalysis (1.194 - 194) <B6934994-BD69-36F9-914E-6BBDCD797612> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff4d704000 - 0x7fff4d722fff com.apple.ProtocolBuffer (1 - 260) <195906B1-1DB1-3AD2-B2F7-87B867C27F40> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff4d8ec000 - 0x7fff4d8f8fff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.70.16) <AEAA88C6-CBB6-3598-9548-E4DF155B4A64> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff4d8f9000 - 0x7fff4d91cffb com.apple.RemoteViewServices (2.0 - 125) <695CBF89-C15C-3E4C-8045-B46DCA64E3FB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff4d91d000 - 0x7fff4d932ff3 com.apple.xpc.RemoteXPC (1.0 - 1205.70.16) <DD597F26-6BBE-3DAD-9257-7A5FCD60C109> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff4f242000 - 0x7fff4f357ff7 com.apple.Sharing (1050.22.9 - 1050.22.9) <CAB71093-B187-363E-BBAA-B0D23D7642AA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff4f382000 - 0x7fff4f383ff7 com.apple.performance.SignpostNotification (1.2.6 - 2.6) <E77879A4-B040-3BE0-86F5-98173A4100AD> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff500e1000 - 0x7fff5037efff com.apple.SkyLight (1.600.0 - 312.103.12) <A65B547C-B7CA-3E33-A0C5-58AB436A8467> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff50b47000 - 0x7fff50b54fff com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <90CDCEAD-5A65-3C35-9370-2B306895E97C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff516fa000 - 0x7fff51783fc7 com.apple.Symbolication (9.3 - 64033) <F576D527-4CB1-34A5-B15E-1130833EEDAB> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff51cf4000 - 0x7fff51cfcff7 com.apple.TCC (1.0 - 1) <9D5466C6-A8B6-3C24-A791-6506B81D9998> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff51f09000 - 0x7fff51fc6ff7 com.apple.TextureIO (3.7 - 3.7) <32C460CD-E93D-3FA5-A4AE-CA648722F5FE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff52077000 - 0x7fff52227fff com.apple.UIFoundation (1.0 - 547.9) <D0994333-5EB4-3415-8D18-2A0487AE91E0> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff52efc000 - 0x7fff52fcbff7 com.apple.ViewBridge (343.2 - 343.2) <0A295791-B763-3E58-A9DD-8E4F40E815C9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff539a3000 - 0x7fff539a5ffb com.apple.loginsupport (1.0 - 1) <E273A65A-6379-3787-B119-BC6ED94D4A81> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff53b0c000 - 0x7fff53b3fff7 libclosured.dylib (551.5) <112BC241-6626-3848-8DD8-B34B5B6F7ABC> /usr/lib/closure/libclosured.dylib
0x7fff53bf9000 - 0x7fff53c32ff7 libCRFSuite.dylib (41) <14B00FCF-4C67-3736-95B5-76FEA6E4972C> /usr/lib/libCRFSuite.dylib
0x7fff53c33000 - 0x7fff53c3efff libChineseTokenizer.dylib (28) <2237A259-0E59-3DD0-BADC-281C361FAB70> /usr/lib/libChineseTokenizer.dylib
0x7fff53cd0000 - 0x7fff53cd1ff3 libDiagnosticMessagesClient.dylib (104) <3F855622-352B-3EA8-B7C8-94D1DB48C080> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff53d08000 - 0x7fff53ed2ff3 libFosl_dynamic.dylib (17.8) <1A2A9D53-129E-3F7D-AE23-1D6E6D9EA017> /usr/lib/libFosl_dynamic.dylib
0x7fff53f0a000 - 0x7fff53f0afff libOpenScriptingUtil.dylib (174) <AC38B2C3-5A37-30EB-A246-CEFABD3DD4E7> /usr/lib/libOpenScriptingUtil.dylib
0x7fff54041000 - 0x7fff54045ffb libScreenReader.dylib (562.18.5) <FFB20E40-7669-30F6-8577-B74E18076376> /usr/lib/libScreenReader.dylib
0x7fff54046000 - 0x7fff54047ffb libSystem.B.dylib (1252.50.4) <5A02016C-8F9D-3F47-8C39-AD2CD4F9F11D> /usr/lib/libSystem.B.dylib
0x7fff540da000 - 0x7fff540dafff libapple_crypto.dylib (109.50.15) <A8DEA8E9-5769-3C78-824D-969A98B94086> /usr/lib/libapple_crypto.dylib
0x7fff540db000 - 0x7fff540f1ff7 libapple_nghttp2.dylib (1.24) <24338D88-5D73-3165-9CFB-5A92734C9040> /usr/lib/libapple_nghttp2.dylib
0x7fff540f2000 - 0x7fff5411cff3 libarchive.2.dylib (54) <D2B6AD30-18CB-3E3C-ABBF-A0745654350F> /usr/lib/libarchive.2.dylib
0x7fff5411d000 - 0x7fff5419efdf libate.dylib (1.13.1) <77603BB8-681D-32A6-966E-4F92B9165447> /usr/lib/libate.dylib
0x7fff541a2000 - 0x7fff541a2ff3 libauto.dylib (187) <92E693DF-D74D-39A0-99AB-8A9F6FFEBA18> /usr/lib/libauto.dylib
0x7fff541a3000 - 0x7fff5425cffb libboringssl.dylib (109.50.15) <FC25FE02-6AA8-3F0B-9EF3-56A455C08C0F> /usr/lib/libboringssl.dylib
0x7fff5425d000 - 0x7fff5426dff3 libbsm.0.dylib (39) <18D57879-A717-3466-9637-1704EE59A32A> /usr/lib/libbsm.0.dylib
0x7fff5426e000 - 0x7fff5427bffb libbz2.1.0.dylib (38) <0B4321CD-3D6F-3095-A12E-27F66B4321AD> /usr/lib/libbz2.1.0.dylib
0x7fff5427c000 - 0x7fff542d2fff libc++.1.dylib (400.9) <142D6292-F30F-3949-9F37-3C97A579F540> /usr/lib/libc++.1.dylib
0x7fff542d3000 - 0x7fff542f7ff7 libc++abi.dylib (400.8.2) <EF5E37D7-11D9-3530-BE45-B986612D13E2> /usr/lib/libc++abi.dylib
0x7fff542f9000 - 0x7fff54309fff libcmph.dylib (6) <890DEC4C-4334-393C-8B56-7C8560BBED9D> /usr/lib/libcmph.dylib
0x7fff5430a000 - 0x7fff54321fcf libcompression.dylib (47.60.2) <543F07BF-2F2F-37D5-9866-E84BF659885B> /usr/lib/libcompression.dylib
0x7fff545cc000 - 0x7fff545e4ff7 libcoretls.dylib (155.50.1) <087E9F90-21E5-376D-9956-C4E346409682> /usr/lib/libcoretls.dylib
0x7fff545e5000 - 0x7fff545e6ff3 libcoretls_cfhelpers.dylib (155.50.1) <78CCDD10-7D71-365E-A0A5-8524ED5F5BF9> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff54ab7000 - 0x7fff54b0cff3 libcups.2.dylib (462.2.10) <590D6ACC-68A0-371E-8646-FC59F814534B> /usr/lib/libcups.2.dylib
0x7fff54c4c000 - 0x7fff54c4cfff libenergytrace.dylib (16) <1F11D488-07C6-3D18-BEF2-0B28A992D761> /usr/lib/libenergytrace.dylib
0x7fff54c4d000 - 0x7fff54c66ff3 libexpat.1.dylib (16.1.1.1) <BF67821E-1B05-3E26-9EE9-4366CC0DAD03> /usr/lib/libexpat.1.dylib
0x7fff54c83000 - 0x7fff54c88ff3 libheimdal-asn1.dylib (520.50.9) <EF65C17E-31CD-31DC-876C-BF3EF393099C> /usr/lib/libheimdal-asn1.dylib
0x7fff54cb4000 - 0x7fff54da5ff7 libiconv.2.dylib (51.50.1) <7965B866-C75A-3450-9891-0500349F7090> /usr/lib/libiconv.2.dylib
0x7fff54da6000 - 0x7fff54fcdffb libicucore.A.dylib (59181.0.1) <17767680-09DF-3954-AB6C-B13B41F92A2E> /usr/lib/libicucore.A.dylib
0x7fff5501a000 - 0x7fff5501bfff liblangid.dylib (128) <C54A2059-A4BE-364B-94C2-581C548459BC> /usr/lib/liblangid.dylib
0x7fff5501c000 - 0x7fff55035ffb liblzma.5.dylib (10) <60BEAB81-CE65-3479-90CC-03325AACEC95> /usr/lib/liblzma.5.dylib
0x7fff55036000 - 0x7fff5504cff7 libmarisa.dylib (9) <47540053-02CF-35F8-A75E-074DB3D51812> /usr/lib/libmarisa.dylib
0x7fff550fd000 - 0x7fff55325ff7 libmecabra.dylib (779.7.6) <B2ACB6A9-91AE-364B-9418-8EB938BF82B6> /usr/lib/libmecabra.dylib
0x7fff554fd000 - 0x7fff55678fff libnetwork.dylib (1229.70.2) <0596A03E-C984-3FE6-B88E-63D5F96EC49A> /usr/lib/libnetwork.dylib
0x7fff556ff000 - 0x7fff55aed7e7 libobjc.A.dylib (723) <843EFB54-EFCC-3A7C-BE11-092B6A556262> /usr/lib/libobjc.A.dylib
0x7fff55b00000 - 0x7fff55b04fff libpam.2.dylib (22) <E5840D63-8506-301A-9182-5000031854E1> /usr/lib/libpam.2.dylib
0x7fff55b07000 - 0x7fff55b3fff7 libpcap.A.dylib (79.20.3) <6A9D27FA-2780-3E96-8B2E-645638AC13AC> /usr/lib/libpcap.A.dylib
0x7fff55bbe000 - 0x7fff55bdaffb libresolv.9.dylib (65.1) <D9BB6307-71E4-3A94-A745-1FCA114C6894> /usr/lib/libresolv.9.dylib
0x7fff55c29000 - 0x7fff55c2aff3 libspindump.dylib (252) <7BE3801C-F1F5-3F54-AB70-9842F8EF3F09> /usr/lib/libspindump.dylib
0x7fff55c2b000 - 0x7fff55dbeff7 libsqlite3.dylib (274.8.1) <FCAD6A57-829E-3701-B16E-1833D620E0E8> /usr/lib/libsqlite3.dylib
0x7fff55f92000 - 0x7fff55ff2ff3 libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
0x7fff55ff3000 - 0x7fff55ff6ffb libutil.dylib (51.20.1) <A50E15F1-20A2-3EA7-A8CE-A43662E18587> /usr/lib/libutil.dylib
0x7fff55ff7000 - 0x7fff56004ff3 libxar.1.dylib (417.1) <351781D5-3CCF-320F-BB5A-4DFCC1CCD31D> /usr/lib/libxar.1.dylib
0x7fff56008000 - 0x7fff560efffb libxml2.2.dylib (31.20) <286F8531-7001-3989-9640-284443355433> /usr/lib/libxml2.2.dylib
0x7fff560f0000 - 0x7fff56118fff libxslt.1.dylib (15.16) <57D56366-1E7B-356C-B2B8-F4688FF666E6> /usr/lib/libxslt.1.dylib
0x7fff56119000 - 0x7fff5612bffb libz.1.dylib (70) <47278BDC-596E-3037-B8DA-05FE9D5DBEF6> /usr/lib/libz.1.dylib
0x7fff561c7000 - 0x7fff561cbff7 libcache.dylib (80) <096D3699-58D2-3D23-9512-BC88DAE7B16C> /usr/lib/system/libcache.dylib
0x7fff561cc000 - 0x7fff561d6ff3 libcommonCrypto.dylib (60118.50.1) <B4E77BD4-A809-37E1-8A79-25955E0F5D9C> /usr/lib/system/libcommonCrypto.dylib
0x7fff561d7000 - 0x7fff561defff libcompiler_rt.dylib (62) <4CEED002-D00B-35F8-B563-0546A5F71A43> /usr/lib/system/libcompiler_rt.dylib
0x7fff561df000 - 0x7fff561e8ffb libcopyfile.dylib (146.50.5) <F7A7999F-9509-3C67-8EE9-95BEE6772676> /usr/lib/system/libcopyfile.dylib
0x7fff561e9000 - 0x7fff5626effb libcorecrypto.dylib (562.70.3) <9C6E5CC2-272B-3740-AEDB-9EBEC98EC7F9> /usr/lib/system/libcorecrypto.dylib
0x7fff562f6000 - 0x7fff5632fff7 libdispatch.dylib (913.60.3) <285526B6-A2A6-316D-A1CC-37803B71E203> /usr/lib/system/libdispatch.dylib
0x7fff56330000 - 0x7fff5634dff7 libdyld.dylib (551.5) <49ABA86D-DD48-3133-9B14-B9A564EEBC66> /usr/lib/system/libdyld.dylib
0x7fff5634e000 - 0x7fff5634effb libkeymgr.dylib (28) <7CC7B5E1-AB7F-3495-A26A-396461BCB66B> /usr/lib/system/libkeymgr.dylib
0x7fff5634f000 - 0x7fff5635bff3 libkxld.dylib (4570.71.82.8) <44AF05D7-6BDF-3A9B-B5CF-D16C98B6844E> /usr/lib/system/libkxld.dylib
0x7fff5635c000 - 0x7fff5635cff7 liblaunch.dylib (1205.70.16) <265EE555-E988-3EE5-A39E-028FB3A5FE11> /usr/lib/system/liblaunch.dylib
0x7fff5635d000 - 0x7fff56361ffb libmacho.dylib (906) <F5F16E2F-F961-3FF4-B02F-69BBDB57B8DC> /usr/lib/system/libmacho.dylib
0x7fff56362000 - 0x7fff56364fff libquarantine.dylib (86.70.1) <262CECFE-A493-3EC6-8608-CEA93757265E> /usr/lib/system/libquarantine.dylib
0x7fff56365000 - 0x7fff56366ff3 libremovefile.dylib (45) <EA24BFB6-24B7-3841-8AAC-FAF400910706> /usr/lib/system/libremovefile.dylib
0x7fff56367000 - 0x7fff5637efff libsystem_asl.dylib (356.70.1) <9481D82D-CFB7-3032-A07F-88F7F59CAC2C> /usr/lib/system/libsystem_asl.dylib
0x7fff5637f000 - 0x7fff5637ffff libsystem_blocks.dylib (67) <FA2C3663-9DBB-3AFB-80A3-E77BE0816AD0> /usr/lib/system/libsystem_blocks.dylib
0x7fff56380000 - 0x7fff56409ff7 libsystem_c.dylib (1244.50.9) <25DD83D8-80CA-3DFF-8626-FE704911F19C> /usr/lib/system/libsystem_c.dylib
0x7fff5640a000 - 0x7fff5640dffb libsystem_configuration.dylib (963.50.9) <61B26E1D-FEFF-38C6-AE0E-A6DD90145EB2> /usr/lib/system/libsystem_configuration.dylib
0x7fff5640e000 - 0x7fff56411ffb libsystem_coreservices.dylib (51) <E8FA663F-1B0F-3B12-8F97-31A46E6B4D68> /usr/lib/system/libsystem_coreservices.dylib
0x7fff56412000 - 0x7fff56413fff libsystem_darwin.dylib (1244.50.9) <6195EEA1-83A7-35F0-8147-5AB031020CD0> /usr/lib/system/libsystem_darwin.dylib
0x7fff56414000 - 0x7fff5641affb libsystem_dnssd.dylib (878.70.4) <0D2C9583-5D28-375B-AEB4-F66F18C78322> /usr/lib/system/libsystem_dnssd.dylib
0x7fff5641b000 - 0x7fff56464ff7 libsystem_info.dylib (517.30.1) <9C2C96F3-638B-34E7-A2BD-24C643EAF957> /usr/lib/system/libsystem_info.dylib
0x7fff56465000 - 0x7fff5648bff7 libsystem_kernel.dylib (4570.71.82.8) <C34BA704-FAFF-3DDB-9827-5930B5BEF134> /usr/lib/system/libsystem_kernel.dylib
0x7fff5648c000 - 0x7fff564d7fcb libsystem_m.dylib (3147.50.1) <B3172533-77D2-3416-8487-4A505198E9E1> /usr/lib/system/libsystem_m.dylib
0x7fff564d8000 - 0x7fff564f7ff7 libsystem_malloc.dylib (140.50.7) <821E16C8-7A7E-3269-9167-10F4F413BF93> /usr/lib/system/libsystem_malloc.dylib
0x7fff564f8000 - 0x7fff56628ff7 libsystem_network.dylib (1229.70.2) <07BFD80A-E7EB-3DEB-B765-5E1659453114> /usr/lib/system/libsystem_network.dylib
0x7fff56629000 - 0x7fff56633ffb libsystem_networkextension.dylib (767.70.2) <A90BAFFD-AC3D-3078-90B2-71463DBFD4A5> /usr/lib/system/libsystem_networkextension.dylib
0x7fff56634000 - 0x7fff5663dff3 libsystem_notify.dylib (172) <738B3BB0-4F20-3446-A3B6-095D796E5903> /usr/lib/system/libsystem_notify.dylib
0x7fff5663e000 - 0x7fff56645ff7 libsystem_platform.dylib (161.50.1) <90A2A62F-8690-3FA7-A4D0-9085BF2FA44A> /usr/lib/system/libsystem_platform.dylib
0x7fff56646000 - 0x7fff56651fff libsystem_pthread.dylib (301.50.1) <283E64A7-A2B2-3212-95BA-4D21F9AE36CF> /usr/lib/system/libsystem_pthread.dylib
0x7fff56652000 - 0x7fff56655fff libsystem_sandbox.dylib (765.70.2) <C29E1B7A-F39B-344E-98F7-8FB32B10AE0A> /usr/lib/system/libsystem_sandbox.dylib
0x7fff56656000 - 0x7fff56657ff3 libsystem_secinit.dylib (30) <4E84DF62-57B5-36F9-819F-3C1E7FEDA856> /usr/lib/system/libsystem_secinit.dylib
0x7fff56658000 - 0x7fff5665fff7 libsystem_symptoms.dylib (820.60.3) <A45B4D84-2C69-3F19-83C2-2F1EEA73A7B5> /usr/lib/system/libsystem_symptoms.dylib
0x7fff56660000 - 0x7fff56674ff7 libsystem_trace.dylib (829.70.2) <4C4E5351-E370-3226-9B30-61E250DE3B2E> /usr/lib/system/libsystem_trace.dylib
0x7fff56676000 - 0x7fff5667bff7 libunwind.dylib (35.3) <BAE12DA3-CF33-32AD-86B0-CCD6705ADFAA> /usr/lib/system/libunwind.dylib
0x7fff5667c000 - 0x7fff566a9fff libxpc.dylib (1205.70.16) <26D99819-B813-320E-9E8F-9D57AD2DA63B> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 8263
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=358.2M resident=0K(0%) swapped_out_or_unallocated=358.2M(100%)
Writable regions: Total=38.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=38.7M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 2
Kernel Alloc Once 8K 2
MALLOC 30.2M 18
MALLOC guard page 32K 9
STACK GUARD 56.0M 2
Stack 8192K 2
__DATA 25.3M 249
__FONT_DATA 4K 2
__LINKEDIT 193.5M 5
__TEXT 164.7M 250
__UNICODE 560K 2
shared memory 12K 4
TOTAL 478.7M 535
Model: MacBookPro11,3, BootROM 162.0.0.0.0, 4 processors, Intel Core i7, 2.5 GHz, 16 GB, SMC 2.19f12
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.37.33.1a1)
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
And what happens with a new empty lightghow ?
Does V9.3.14 run correctly, or does it crash too ?
Return to “General software”
