TheLightingController crashes Randomly
Re: TheLightingController crashes Randomly
9.3.8 crashed today, so going back to 9.2.38
We found a minor memory leak in the hardware library.
This fixed problem will not change anything on Windows, but it may on MacOS (Unix based systems are more sensible).
This fixed problem should fix a possible error message when you quit our software on MacOS.
We are not sure it will help for your problem, but it worth a try.
Please try the new fix file: https://download.thelightingcontroller. ... ew/fix.zip
In case of MacOS signature problem, we made also a new DMG file for you here: https://download.thelightingcontroller. ... roller.dmg
In all cases, do not forget to copy the file "efk_hardware.dylib" ; this is the only updated file.
Thanks, needed the DMG version, downloaded and giving 9.3.10 a try... (
Well that didn't last long, just crashed again... back to 9.2.38
Noted.
And no crash with V9.2.38 ?
Crashes with 9.2.38 happen, but are more rare since MacOS 13.5.2, like maybe once a month.
The binary file of the current fix for V9.3.11 has been recompiled with a new compiler.
Thanks, if you're referring to this link https://download.thelightingcontroller. ... ew/fix.zip it (after forcing it to open in Privacy & Security) gives me
"Error loading library 'efk_hardware' !"
Noted.
Please try that one: https://download.thelightingcontroller. ... roller.dmg
This link gets me 9.3.10 (dated Oct 12)
