martin mac allure needs to be fixed
Gabriel070
Post by Gabriel070 »
hi the martin mac allure (68 channel) shows up as 7 different moving heads but linked, on 3D view, (could you fix that). i believe its because the allures have a specific feature that separate the colours and individually show up (7 segments effect) as in this video. https://www.youtube.com/watch?v=iEpDR_jH26g (could also make that effect on the program)
Re: martin mac allure needs to be fixed
Sorry but 3DView is not able to show a multi-segments beam.
FYI: https://forum.thelightingcontroller.com ... f=13&t=668
Gabriel070
thats ok but did you fix the 7 different fixtures playing as one on 3d view (mac allure 68 channel).
this is what it does.
Post by SeekLighting »
Gabriel070 wrote:thats ok but did you fix the 7 different fixtures playing as one on 3d view (mac allure 68 channel).
From what I understand, it's supposed to do that. What you can do to get a close recreation of the multi-element fixture is drag all 7 heads together so they sit on top of each other. That's as close as you're going to get I believe.
Gabriel070
ok thank you, i put them all together but the only problem is that the clarity of the light fixtures together is very bright
You can reduce the power of the beam, in the properties of the fixture.
Return to “3DView”
