different fixtures not working well together [fixed]
jason5d
Post by jason5d »
Hi
I'm trying to make some generator movement only programs with Chauvet Trio and Chauvet 357z irc movers but the pan/tilt channel doesn't show in channels menu.
Ive tried it with 30ch and 15ch on the Trios - no joy
thx
Re: different fixtures not working well together
We checked the profiles and we found an error in the IntimidatorSpot375ZIRC(15ch) model.
The fourth channel is "pan fine" instead of "tilt fine".
Please use the attached updated file.
IntimidatorSpot375ZIRC(15ch).txt
(2.49 KiB) Downloaded 837 times
jason5d
Post by jason5d »
thx,
that works with the trio 30ch version, I've noticed the trio 30ch doc has some errors please check the 1st mode channel
here's the Manual:
https://www.chauvetdj.com/wp-content/up ... M_Rev5.pdf
Any chance you can add button in steps menu at the top that can change all fade/step buttons to step
Noted.
To do that:
jason5d
Re: different fixtures not working well together [fixed]
Post by jason5d »
I mean all the channels. eg when you click said button all the dmx channels across the step menu would change to step and when I click again they would change back to fade
thx
For that, select all channels (ctrl or shift + mouse click) (red check mark) and press the transition button of any of them.
Return to “Editor - Generator”
