3D Window (V5.1.0) won't start [fixed]
BuBulle
Re: 3D Window won't start
Post by BuBulle »
I just did an important test:
- created a new lightshow on same computer
- copied fixtures.ini and fixtures directory from faulty directory to new lightshow : 3DView won't start ! That"s good information, problem is either in
fixtures.ini or one of the fixtures files.
BuBulle
Post by BuBulle »
I look at the last modified fixture file from the faulty show
copied one I backed up recently
IT WORKS AGAIN :)
so this fixture file must have been corrupted.
Lessons Learned:
- frequent named backups, at least on config changes and major scene updates
- if this happens again I know 3Dview looks at fixtures.ini and individual fixture files.
Thanks for those who tried to help,
Luc Henrion
Post by Luc Henrion »
Great ! Good job. Did you keep the corrupted file so you could check what was wrong with(in) it ?
Yes, if possible please post the "working" and the "corrupted" files.
This may speed up things for us to fix that problem.
BuBulle
Post by BuBulle »
Enclosed the faulty file. You will see that it starts with head "4" and ends with head "1"
I now recall I wanted to revert the order as moving heads appears in the reverse order i wanted. #1 was right and #4 was left. I wanted the opposite. So using Editor/Fixtures/Edit Fixture I moved each head using up and down arrows.
To confirm this was the problem I now reproduced the issue by naming heads "4" to "1": no 3Dview.
And moved them back "1" to "4" : 3D view fine.
3rd lesson learned : do no move heads order.
Is there a way to reverse heads for a multihead bar ? From left-right to right-left ?
Hydrabeam4000(19ch) - faulty.txt
Corrupted file
(2.83 KiB) Downloaded 1349 times
BuBulle
Post by BuBulle »
Correct file
Hydrabeam4000(19ch).txt
Correct file
(2.83 KiB) Downloaded 1336 times
Thank you for your help.
Fixed in the fix file.
https://forum.thelightingcontroller.com ... =85&t=3438
Return to “3DView”
