Here's the issue:
I have setup a solo narrator spot using STEPS...I've created a button for said solo narrator spot so that when the button is pressed the solo narrator spot lights the narrator. I do not have a specific timeframe for when the narrator will be finished with narration. So, I have another button for a timeline I've created that starts with the same solo narrator spot STEP and also contains multiple cues that lights a choir, soloists, etc.
When I press the solo narrator spot it lights up the narrator perfectly, however, when I press the timeline button that should KEEP the narrator spot, it cuts the light out for a split second then transitions back in to the narrator spot.
I need to be able to start the timeline and CONTINUE to light the narrator without a break in lighting.
Any help on how I can accomplish this??
Thanks,
Jeremy
