V9 Beta - Custom Fixture Profile Not Working
Pink LD
Post by Pink LD »
v9.05beta5 - 180815 - 64Bits
(Please note I am not using the latest Fix File posted, it crashed the software and it wouldn't open. So I rolled back.)
This is a profile I made for the ADJ Pro64 LED (7Ch). The dimmer now activates a NC in 3D when I use it. This works in V8. I use the 4th Channel's colour macro for a NC override. But this fixture is now unusable in V9 3D. See the following pictures:
https://drive.google.com/file/d/1SNBek- ... p=drivesdk
https://drive.google.com/file/d/1GlXXfy ... p=drivesdk
marco
Re: V9 Beta - Custom Fixture Profile Not Working
Post by marco »
Dit u create the fixture in v8 or in v9, if in v8 try deleting the channel that doesnt work and add it new,
I had a simular problem with a led par profile from v8,
Try editing the profile, delete all channels leave the rgb (create a 3 channel fixture)
Then add the remaining channels new, this worked for me
It seems that not all fixtures of v8 work correct in v9
Pink LD
Post by Pink LD »
Nothing I have tried, nor your solutions worked. I can either make a work-around, or just change my programming to not use the Colour Macro channel call of a value of 42 and instead just bring up the RGB faders and effectively. For some reason, years ago calling the Macro colour made sense but I can work around that reason as well.
3D V8 and 3D V9 show both the same result with this fixture here.
We do not really understand what is the problem.
Can you please give us more details ?
Pink LD
Post by Pink LD »
I finally fixed it, but I did have to tweak the profile to make it work in V9. I was actually going to suggest you delete this but if you would like an explanation I could give you one.
Post by SeekLighting »
If you could explain the problem that would be sweet. I've never experienced this issue, and I use a lot of custom profiles I made in V8, however I'd like to know what went wrong here in case I do encounter this! :)
Pink LD
Post by Pink LD »
It just took a lot of fooling around with the settings to find the right combinations that worked.
Return to “Editor - Fixtures”
