Tomshine 40W Stage Lighting 12 LED RGBW
djayabsolute
I created a 13 channel profile for this fixture however, i don't think it is working right in the 3d view. the color changes however there is no strobe. channel 12 seems out of order because of the dmx value in the manual . I also notice that the manual does not say the make of the fixture. on amazon where i purchased the light, description states that it is a 14/16 channel dmx light but the manual that came with it says 7/13 channels. i have attached the manual with this message. can someone help? thanks
Re: Tomshine 40W Stage Lighting 12 LED RGBW
Tu avais plusieurs erreurs, essaie le fichier ci-joint, mais il faudra que tu rentres tes valeurs du pan et tilt.
Attention, si tu es sur la version 8, il y a un correctif ici https://thelightingcontroller.com/viewt ... =13&t=5432 pour le random et pulse (pour le canal 12).
- Tomshine led mini moving head light 12pcs.txt
- (717 Bytes) Downloaded 1099 times
djayabsolute
thank you i will try it
