Timeline ends at 0:30:00
andypresovsky
Post by andypresovsky »
Hello guys,
I came into a problem which I can not solve at the moment. If you had similar experience, please let me know the solution.
I have been trying to create timeline with scenes, but at 0:29:52 the timeline stops and does not allow me to add new scenes.
Screenshot is attached.
Thank you very much in advance.
Andy
[image]
Re: Timeline stops at 0:29:52
Looks like the timeline duration is 30mn (which is the default duration).
You can change that duration in the window "Timeline settings".
andypresovsky
Hi guys,
I found that with timeline saved there is file timeline.ini and there you can change the value
MaxTime = 0:30:00
to desired value.
Then it works.
andypresovsky
support wrote:Looks like the timeline duration is 30mn (which is the default duration).
Thank you very much. Now I read your answer.
Your solution is cleaner than to edit the text file. I will use it next time. I do not know why I have not seen the Timeline settings option - probably I was not searching well enough.
Thank you again for your support.
You are welcome.
Please note that all parameters in the text file are adjustable in the software.
Return to “Live - TimeLine”
