ADJ - Pocket Pro
garslacour
ADJ - Pocket Pro
Bonjour est il possible d avoir l editor pour Adj Pocket Pro ?
Lien :
http://www.adj.com/pocket-pro
http://cdb-cdn.adj.com/ItemRelatedFiles ... et_pro.pdf
Merci par avance.
Lien :
Merci par avance.
garslacour
Re: ADJ - Pocket Pro
Merci du travail.
Par contre ou puis je trouvé le fichier ?
Dans le lien indiqué ici : https://forum.thelightingcontroller.com ... f=3&t=2453
I'm also searching for how to use the ADJ Pocket pro with this software. I've tried to do it manually however I'm very new to DMX and could not get anything working. Please help if anyone has a profile for this fixture.
Many thanks
Many thanks
Go to the following link:tonytone wrote:I'm also searching for how to use the ADJ Pocket pro with this software. I've tried to do it manually however I'm very new to DMX and could not get anything working. Please help if anyone has a profile for this fixture.
Many thanks
http://download.thelightingcontroller.c ... or_Editor/
Excellent thank you. In the meantime I have connected some simpler lights to try and control however things are not working correctly and its annoying. Tried the fixtures with ADJ MyDMX and they work but I cant get them to work in QuickDMX. I have added a fixture, set the address on the light. Clicked on the steps tab and moved the sliders around however nothing. There is some communication if I click on the DMX (green) icon the light turns off. If I disable the DMX icon (red) the lights are on as though the light is on as if in sound to light mode and no DMX control is working.
I have tried 3 fixtures where none have worked
Ok I closed QuickDMX and reopened which did the trick!
I've got the pocket pro working now however I can imagine its going to take me ages to program them and could do with some programs for a few gigs I have coming up in the next few days. Would anyone know if there is anywhere to download any programs/scenes from please?
Thanks.
Thanks.
I don't have a pocket pro but I can give you my workflow which is quite fast for me.tonytone wrote:I've got the pocket pro working now however I can imagine its going to take me ages to program them and could do with some programs for a few gigs I have coming up in the next few days. Would anyone know if there is anywhere to download any programs/scenes from please?
Thanks.
1. Make sure you can turn on the lamp. I know it's basic but you can't imagine how often I missed that step and the lamps didn't turn on at the moment I wanted them.
2. Program movements and positions (use the generator for movements)
3. Program colours and gobo's.
4. Program effects like dimmer chases or whatever you come up with that you think might look cool.
