add a fixture crashes [fixed]
joefish1969
Post by joefish1969 »
Hello all i just got a new computer running windows 10 iinstalled showxpress and when i try to add a fixture windows crashes. Also when i try to import a light show it doesn't work. I am pretty familar with showxpress but cannot figure this one out. The guys at Chauvet can't figure it out either. Please Help
Re: Windows 10 problems
Please post a link to download your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168). We will check it.
And if possible, post a video (YouTube) showing the crash. This usually speed up things to fix the problem.
joefish1969
Showxpress crashes when i try to add a light fixture. Also when i try to import a light show it doesnt work. It says import complete but doesnt show up. I import it to other computers and it works fine so it is not the lightshow file. This is a brand new computer. All my other software works fine, serato, Virtual Dj, Etc. i Also installed older versions and that didn't work either. Everything works fine on my other windows 10 pc running home edition.
I also tried it in safe mode and have the same results.
https://www.youtube.com/watch?v=4B1LzzGMwNA
My Operating system is Windows 10 Home
Processor Intel(R)Core(TM) i7-7700HQ CPU @2.80 GHZ
64 Bit
Computer is a lenovo 720 Yoga
Please find the folder "TheLightingController", which is stored in the "home directory" of your computer. Make a zip of this folder and send it to us.
This folder contains all data of our software installed in your computer ; we would like to check it.
joefish1969
Zip File
TheLightingController.zip
Zip File
(443 Bytes) Downloaded 1101 times
The folder "LightShows" is not present in the folder "TheLightingController". This is not normal.
Please check that.
joefish1969
The reason is its a new install on new computer it will not let me make import a light show, or add a fixture. when i add the light show folder from my other computer to the lighting controller folder it does not show up in showxpress. i have showxpress on 5 different computers and they all work fine. the lightshow folder works i tried it on different computers. even though there isn't a light show folder in the lighting controller folder you should still be able to add a fixtures and patch it am i correct on this ? i need this resolves asap have many light shows coming up on new years for different clients.
joefish1969
I added the lightshow folder again to showxpress and it worked i don't know why i did this like 10 times i reinstalled it like 10 times and added again and now this time it worked so i guess problem solved for now.
Return to “Windows”
