Marq - Gesture spot 300
chrishooksbass
Post by chrishooksbass »
the shutter and color are reversed when i program in generator.
shutter = color
color = shutter
any help would be appreciated.
thank you
Re: Marq gesture spot 300 generator Question
Please post (or email us) the profile.
We will fix it for you.
chrishooksbass
thanks!
mark lighting gesture spot 300 (the 13 channel is where the error occurred,i didn't try the 7 channel.
i really appreciate it.
http://www.marqlighting.com/products/vi ... e-spot-300
http://0ab2dada4ff5ab031e87-2647250b48e ... 20v1.5.pdf
Please try that attached one, and let us know.
Gesture Spot 300 (13CH).txt
(2.42 KiB) Downloaded 962 times
chrishooksbass
Re: Marq - Gesture spot 300
thanks
it added more errors
color-shutter reversed, and gobo (rotation) movement got reassigned
i reverted to the original and found the color and shutter reversed when i checked the edit fixture .
i reversed the color and shutter and now it works perfectly.
thanks again for your time
i love this software!
Noted.
Thank you !
