[Bug] Master-fader and midi note v8.2.4 [fixed]
thorehl
Post by thorehl »
As with buttons, I like having buttons light up when things are ON.
So i tried on my APC:
Assigned Master fader 2 (In): Control 48 /
Assigned Master fader 2 (Out): Note 64, D2on 1, D2off 0
This doesn't work, but it does if I do the same on Speed fader.
And why is it, when i assign a Master fader, it only controls the dimmer from -100% to 0% and the area from 0 to 100% is unused?
Thore
Controller: 2x Akai APC mini
my DIY light mixer
Re: [Bug] Master-fader and midi note v8.2.4
We do not see this problem here, with our APC mini.
thorehl
Post by thorehl »
thorehl wrote:As with buttons, I like having buttons light up when things are ON.
Tried some more...
Turns out, Master fader 2 (Out) values aren't stored induvidualy.
If I save as above, go back in all is ok but it doesn't work.
Exit program, restart program the values are changed to:
: Control 48, Auto, Auto
rather than
support wrote: We do not see this problem here, with our APC mini.
thorehl wrote: when i assign a Master fader, it only controls the dimmer from -100% to 0%
Well you have my showfile from the other post (Midnight Special.zip)
You can test.
[Edit]
Tested some more...
-100% = 000 DMX value
-50% = 128 DMX value
0% = 255 DMX value
50% = 255 value
100% = 255 value
this is weird behavor, as only 50% of the fysical fader movment is used
Thore
my DIY light mixer
thorehl wrote: Turns out, Master fader 2 (Out) values aren't stored induvidualy.
rather than
Fixed for next fix file (8.2.5+)
thorehl
Post by thorehl »
Thanks.
Now it's loading correct values, but midi commands are not.
If i set D2on/D2off
: 1/0 lamp is constantly light
: 0/1 lamp is constantly off
Midi controller fader movment doesn't affect lamps on controller (as if midi out isn't working for master fader) but if i use the mouse lamps turn on or off depending on what D2on/off is set to.
Thore
my DIY light mixer
Yes we saw that. We will see if we can do something.
Fixed for next fix file (8.2.6+)
thorehl
Post by thorehl »
Many thanks to you two :)
Thore
my DIY light mixer
The fix is online.
Return to “Live - Buttons”
