StandAlone Calendar Trigger
Jeffrey
Post by Jeffrey »
Unable to get the Calendar triggers (On/Off) in StandAlone to control the scene when attached to Power Supply.
If I enable the "Auto Start" button, the scene plays but ignores the Calendar On/Off settings.
Is there a sequence or list of basic instructions for getting this function to work?
We are using an older Xpress 512 Plus
S/N: 11100701087
Thanks for the help.
Re: StandAlone Calendar Trigger
Please send us your lightshow.
viewtopic.php?f=3&t=168
We will check that.
Jeffrey
Post by Jeffrey »
Did you receive my email?
It works here, but please note that the scene running behaviour in standalone is slightly different than in PC mode.
In PC mode, the software knows the last step, so it is able to start by playing the first step (with a transition from the last step).
In standalone mode, the interface does not know the last step, so it play the second step (with a transition from the first step).
And all channels in the second step of your scene are null. So you have to wait for more than 50s to see the step 3.
Return to “StandAlone”
