Hey,
Right now my speed slider controls all three things speed related
It was it being run in this video but I cant figure out how they managed to separate them
https://www.youtube.com/watch?v=vncJ7NG ... e=youtu.be
In this video they have 4 speed sliders,
Position, Moment, Effect and Color. If someone could help me understand how this was done, it would very helpful.
thanks
CD
Speed Sliders [fixed]
Re: Speed Sliders
Don't know if I can fully explain what you are looking for but when you right click on your slider, you can select channels. In the instance in my show they are all dimmers but..... if you notice when you right click on the slider, there is a type option. Within the type option you can change the slider from a dimmer control to a speed control. Once you select the speed control option, you will lose the channel select option within the menu so I can only assume that you need to make the selection as a dimmer then change it to the speed type option. I haven't tested this but will do so this evening if possible and reply with my results if you don't get to it before I do.
This is running V8.
This is running V8.
Re: Speed Sliders
In the "speed properties" of your button, you can choose the master speed fader
