we' ve some new RGB Fixtures (Elation's Cue Pix Batten) with 36 Channels and want to use them in PIXEL Menu.
First 30 Channels = 10 times RGB.
31 = Color Macro
32 = Strobe Effect
33 = Dimmer
34 = Effect Macro
35 = Effect Speed
36 = Dimmer Curve
Am I right that's not possible to choose Channel 31 - 36 as "Shared Channels" because in Pixel Menu are "only" 30Channels available?
Using 7.1.85
greetings
How to set shared channels from 31 to 36 [fixed]
MTF Showtechnic
Re: Shared Channels again
"Last channels" is the number of last channels. So in your case, you have to set it to value 6.
MTF Showtechnic
Re: How to set shared channels from 31 to 36 [fixed]
Thanxs again,
now we've understood how to proceed with Channel Setting in the Pixel Menu.
Furthermore I've changed the german translation in the correspondent file.
greetings
greetings
