I have 4 moving heads which show up in the 3d view, they move fine but there's no beam showing. The dimmer is up the shutter is open. In the fixtures edit they show 3d view section they show:
Moving head spot
power 575w
Beam aperture 20
Pan 120
tilt 90
beam color white Although "beam color" is greyed out
In the 3D view settings the beam intensity is up and everything looks like it should work ok.
My other fixtures show up fine so i can't see why these don't?
Any ideas anyone?
paul
No beam showing in 3d view
Re: No beam showing in 3d view
Please post the personality file (.txt) ; we will check it.
Do you mean the fixture profile? Where do i find the personality profile?
I just searched fpor personality in the lighting controller file and got the file attached. Is that what you need?
- English.ini
- (30.98 KiB) Downloaded 1066 times
No, it is'nt.
You can simply post your entire lightshow ; we will find the personality file in it.
Ok ....where do i find that? The folder that contains my light show is 900Mb I'm guessing that's not what you want?
Sorry for not understanding.
So please send the file with the name of the fixture followed by ".txt", which is stored in this folder: "../YourLightshow/fixtures/".
(replace YourLightshow by the name of your lightshow)
