Hey
I'm using 6 ADJ megabar 50s with an xpress100 cable. I'm utilizing a program in the light bars that fades from color to color and I want them to all fade to the same color at the same time...for example, all lights could be red, and then fade to blue all at once. The problem is that when I set it up its fine but after a few tiems of testing it they become unsynced so all the lights fade different colors at different times.
Colorfade program not in sync with all lights [fixed]
punkkipper
Re: Colorfade program not in sync with all lights
Hi
Thats normal
it doesnt come from this program, the internal fade times from autoprograms in a fixture arent the same.
i got the same with normal led pars on a normal table and on sweetlight.
solution program the fades in editor then they al work together.
like step 1 is red step 2 is bleu step 3 is green
Thats normal
