Blue channel not working on a par...
create scenes with steps
CHR1155
Post by CHR1155 »
Hey all,
Bit of a strange one but for some reason 1 of my 8 pars isn't responding properly, any ideas?
This is the light in question...
Cheers,
Chris
lse
Re: Blue channel not working on a par...
Post by lse »
Check dmx biography and see if dimmer is at 100 for chanel 7.does it turn on when you turn dimmer off? Did you create the fixture or upload a profile
CHR1155
Post by CHR1155 »
lse wrote:Check dmx biography and see if dimmer is at 100 for chanel 7.does it turn on when you turn dimmer off? Did you create the fixture or upload a profile
Did you mean the "DMX Bargraph"? if so, this is the result! The line already has yellow properties too it? I tried other lights in the group of lights and they don't do the same thing?
lse
Post by lse »
You are not getting the blue channel 3 to dmx.
lse
Post by lse »
Check your master faders and make sure they are not assigned to it.
The yellow line means this channel is linked to a dmx/midi input.
Return to “Editor - Steps”
