hi can i have the profile for Equinox slender beam thank you
http://images.getinthemix.com/resources ... 474_94.pdf
Prolight - EquinoxSlenderBeam
Re: profile
Done.
For the best possible software using, we have created 3 profiles:
- Prolight_EquinoxSlenderBeam(39ch_first)
- Prolight_EquinoxSlenderBeam(39ch_head)
- Prolight_EquinoxSlenderBeam(39ch_last)
If your fixture is at dmx address #1, you have to declare:
#001 - Prolight_EquinoxSlenderBeam(39ch_first)
#002 - Prolight_EquinoxSlenderBeam(39ch_head)
#008 - Prolight_EquinoxSlenderBeam(39ch_head)
#014 - Prolight_EquinoxSlenderBeam(39ch_head)
#020 - Prolight_EquinoxSlenderBeam(39ch_head)
#026 - Prolight_EquinoxSlenderBeam(39ch_head)
#032 - Prolight_EquinoxSlenderBeam(39ch_head)
#038 - Prolight_EquinoxSlenderBeam(39ch_last)
Re: Prolight - EquinoxSlenderBeam
hi where do u send this to please
Please read this: viewtopic.php?f=3&t=2453
thank you i have find them but the Equinox slender beam is nit right pleses can u have a look thank you
Sorry but we do not have the real unit with us, for double checking.
We just refer to the PDF manual.
ok but you say it a 32 channel but yours is not
1 is 2 .
2 has 1.
3 has 6 channels
i will send you this agean
thanks for you helphttps://prolight.co.uk/images//media/EQLED022A/EQLED022A-um0.pdf?ProlightConcepts=66156362910ca5e8db8c2dcc7152c41b
1 is 2 .
2 has 1.
3 has 6 channels
Sorry we made a small mistake regarding the addressing.
#003 - Prolight_EquinoxSlenderBeam(39ch_head)
#009 - Prolight_EquinoxSlenderBeam(39ch_head)
#015 - Prolight_EquinoxSlenderBeam(39ch_head)
#021 - Prolight_EquinoxSlenderBeam(39ch_head)
#027 - Prolight_EquinoxSlenderBeam(39ch_head)
#033 - Prolight_EquinoxSlenderBeam(39ch_head)
#039 - Prolight_EquinoxSlenderBeam(39ch_last)
i I am very confused what is this have 3 profiles
For the best possible software using, you have to declare 6 different fixtures with "pan/tilt", plus one fixture with "dimmer/shutter", plus one fixture with "control" channel. This is the only way to be able to make nice movement effects in the section "Generator" of our software.
