Solo button groups
Detour DJ
Solo button groups
Post by Detour DJ »
Hi all,
I've got a feature request that I think would be awesome: Solo Button Groups. Right now, we can assign all the buttons in a Live Page to solo, and then they only allow one button at a time. I use this a lot, but often it's inconvenient to group ALL the buttons in a page to solo.
For example, I use 8 pages in each of the 2 Live windows. One page is dedicated to Master FX and Followspots. This includes strobing, blinder effects, pulsing effects, smoke machine run, and various full/dim/black settings for 3 followspots. I'd really like to be able to solo just the followspots on that page, but not the other buttons. The followspots only use 7 buttons, so assigning them to their own page and setting that page to Solo would waste screen space.
That's where the concept of assignable solo button grouping would be nice. I'm not sure how you would implement it, but it would be useful to have customizable Solo Groups within pages and have only certain buttons cancel each other out.
Ideally, making the pages fully customizable in size, number and placement would solve the solo issue and many others, but I'll take any improvements the designers wish to work on. Thanks for a great product!
Larz
Larz Hanson
Owner-Operator
Detour DJ, Sound & Lighting
7431 Frontage Road NW
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
http://www.DetourDJ.com
Earl Harvey
Re: Solo button groups
Post by Earl Harvey »
Try using a page of Macros in solo mode?
Detour DJ
Post by Detour DJ »
I already use that feature for master scenes. The concept here is to have a small group of self-canceling buttons without committing a minimum of 1/8 of your available screen space to do it. Alternately, a programmable solo group might even span the entire screen and eliminate the limited per-page solo function. Consider this: In Editor, you can program custom groups of light fixtures. In Live, you can program custom Macros to turn on/off several buttons at once. My idea is an extension of these other two features. Perhaps instead of a "scene" Macro, how about a "solo" Macro that allows you to group any combination of buttons and have them self-cancel among the group? This would be an amazingly useful and versatile feature!
Larz Hanson
Owner-Operator
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
Pink LD
Post by Pink LD »
I like the idea. But with 2 tabbed pages in Live, and the Child Window on a second screen, I can achieve that. But on a single scree, 8 window setup? Sure that level of personalisation would be grand. The software is generally LTP and so it is fairly easy to stack features on each other, plus the software considers macro to macro the order of left top to bottom to right top to bottom, from page 1 to however many pages you have.
In my case all over-ride commands are on pages that start with the letter "Z" in their name.
Also, depending on what you need to do, you can make scenes and/or Macros in pages as flash buttons in Solo Pages. So whatever you need to be flashed will do so while not disengaging the solo scene/Macro that is currently solo. Ergo when you release the flash scene/Macro the solo button that was up before the flash button, is still in charge.
ineedabeatdj
Post by ineedabeatdj »
A great way to implement this would to be able to add solo buttons to within a column on a page. Say you have 6 vertical columns on the page, you could make column 1 and column 6 solo buttons. That way column 1 would all solo together, and column 6 would all solo together separately from solo 1. Not sure if this is possible to implement with the software though? Or even column 1 & 6 would solo together and the other columns would be normal.
Bakenectar
Post by Bakenectar »
AGREED^^
This would be really helpful!!
Detour DJ
Post by Detour DJ »
Good suggestion. Really, I think any way to implement a focused method of selective soloing within pages would be very useful.
Larz Hanson
Owner-Operator
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
Light_user
Post by Light_user »
2nd this, would be great feature.
(also created a topic about this in other thread viewtopic.php?f=75&t=4848)
solo button option is waste of display space when putting 8 seperate page blocks on a display
Detour DJ
Post by Detour DJ »
I always set up my screen with 8 pages, and I find the solo function useful on two of them (Master Scenes and Movers FX). On the other 6, I'd love to have an option to solo just certain buttons, but not the whole page. For example, I have separate color control over 6 groups of LED color fixtures using Preset buttons. On the same page, I use Macros to change all 6 Preset buttons at once to color themes. It would be nice if I could solo just the Macro buttons on that page to toggle among themselves without effecting the individual Preset buttons that the Macro buttons control.
Larz Hanson
Owner-Operator
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
BartKrap
Post by BartKrap »
+1
Return to “Live - Buttons”
