How can I fade lights up from off to full at a time interval of my choice (like 5 secs).
If I use the steps in the editor tab, it cycles back to black and then repeats. Is there a "stop/run" step command or what am I missing/not the correct approach?
fade up lights without looping [fixed]
Lighter007
Re: fade up lights
As far as I know there are three ways to do this:
1. Create a new scene with only one step. Set your dimmer/red/green etc channels where you want them to fade to. Set "Fade state" to "fade" (little symbol under each channel). Adjust the time and save your scene.
Now add the light scene to your live screen. When you click on it your dimmer will fade up.
2. Add the scene to your live screen as you did it but right-click on it and select scene settings. Here you can set the loop on 1.
3. May be the easiest: Create a scene with one step. Set your channels to where you want to have them. Now save and add this scene to your live screen. And now
right-click and select "Fade in" and/or "Fade out".
Done
maybe hard to understand but easy to do if you know how
Lighter007
Done
Lighter007
Greetings from Germany!
Re: fade up lights without looping
Thx, I took the more simple route with the fade time in the Live tab. Worked just fine for what I wanted. Thanks again.
