No Gobo Q Spot 260 version 7.1.5 [fixed]
Earl Harvey
Post by Earl Harvey »
Hey guys... Just noticed no Gobos in 3D for Q Spot 260 in version 7.1.5 on PC win 7/64 pro :o
Thanks,Earl
danilolpo
Re: No Gobo Q Spot 260 version 7.1.5
Post by danilolpo »
Hey Earl,
Sorry for taking so long to reply, I was just made aware of your issue. I will look into this for you.
Is this the only fixture you noticed missing the Gobos?
Danilo Oliveira
Product Engineer Supervisor
Chauvet Professional
Earl Harvey
Yes... Thanks a lot ! You guys have been fantastic 8-)
Earl Harvey
Allan
Post by Allan »
Hi Earl,
Attached are the profiles that you need. Please note that we could not finish the profile perfectly because we do not have a unit here to confirm the gobo patterns within each wheel’s position. What this means to you is that some gobos will work while others will not. Please put the attached profiles into the following file directory and remember to substitute your computer’s name as well as your show’s file for the correct one:
C:\Users\<name>\TheLightingController\LightShows\<show>\fixtures
Please let me know if you have any trouble with this and I’m glad to help you.
Q-Spot 260-LED (14CH).txt
(2.21 KiB) Downloaded 1153 times
Q-Spot 260-LED (11CH).txt
(2.15 KiB) Downloaded 1162 times
Allan Reiss
Senior Product Manager
CHAUVET DJ
Earl Harvey
Thank you very much Alan! Much appreciated!
I'll give a follow up when I get back to the office and get it properly loaded !
Earl Harvey
Working great ! I can edit them to orientate the gobos correctly... Thanks again !
Allan
Re: No Gobo Q Spot 260 version 7.1.5 [fixed]
Post by Allan »
No problem! Happy Programming!
Allan Reiss
CHAUVET DJ
Return to “3DView”
