Earl's Screenshots, Version 7
Earl Harvey
Here's a quick post of my show still in transitional phase...
24 Par 64 LED
4 Q-Spot 260s
2 FX-12 Strobes
1 X-Laser
4 Mini Strips
8 slim 64 pucks
I usually come up with a scene and assign it to a macro... macro 2 I use for strobes and hazer control
I use a Novation Launchpad Mini and Midi Designer on an iPad routed thru MIDI-OX on a PC win 7/64 pro to merge the midi...
I'll try to edit this post as I go along feel free to add any comments or suggestions...
Previously I used an Obey 70 so hence the setup
24 Par 64 LED
4 Q-Spot 260s
2 FX-12 Strobes
1 X-Laser
4 Mini Strips
8 slim 64 pucks
- 10457730_4325503593169_5904663018628281628_o.jpg (184.52 KiB) Viewed 65217 times
- 10397072_4325532073881_1168904005273444713_o.jpg (177.16 KiB) Viewed 65217 times
Re: Earl's Screenshots, 7 Alpha 2
This is the first impressive V7 screenshots we see.
Thank you for sharing !
Lighter007
Whats this thing in your pictures in your 2nd Post? Is it a MIDI Controller? Looks really nice
Greetings from Germany!
Earl Harvey
It an app for the iPad called Midi Designer, you can create your own controllers
http://mididesigner.com/
Can you please tell us what OS are you using to run the software ?
(it looks like Windows 98 or 2000)
Earl Harvey
Im using Windows 7/64 bit Pro
Earl Harvey
Thanks again for all the help during the past 2 years... Show Xpress has become my favorite trick to pull out of my hat...
It would be interesting to attach a "Strobe Generator" similar to the FX-12 to one of the Master faders so it could be applied to selected fixtures...
I would also like to suggest an optional Master Speed Slider, it would free up the Midi Trigger to use for Toggle/Momentary Midi Triggering...
Thanks to everyone who has posted their screenshots they really help when your just starting to learn Show Express
Earl Harvey
