song triggered timing
davidphoenix
Post by davidphoenix »
I'm using the showxpress plugin for virtual dj. I seem to be having a hard time getting the lights to trigger at the same time every time the cue point hits. Some time it's too fast, other times it's too slow. And then as the scene gets further in, it will start to fall off track from the BPM even worse. Sometimes it will miss a step all together.
I'm using OSX 10.8 with the Showexpress Plus interface. I'm running 3 chauvet hemisphere 5.1's and 7 chauvet Color Palettes.
Not sure of any other info you may need but any help would be immensely appreciated!! :)
David.
Re: song triggered timing
Virtual DJ plugin under MacOS
So far, this plugin exists only on Windows !
Can you please confirm you use our software under MacOS with the Virtual DJ plugin ?
DHoude
Post by DHoude »
I was talking with him on the VDJ forum. He is using MAC for Show Express only. He is using PC for VDJ, then sending the plugin signal to the MAC. Will update after we chat this week to sort this out.
Return to “General software”
