For example in this post viewtopic.php?f=40&t=1181 Live_Mobile is used without a WLAN-Router, isn´t it???
But how does it work? Can you also run the app when you make a hotspot with your smartphone? Or can you do something with virtual-private-networks or so?
It would be very good if it works without a router and i saw many pictures where it is used and there CAN´NT be a router!
Running app without WLAN-Router
Lighter007
Greetings from Germany!
Re: Running app without WLAN-Router
i'm using a samsung galaxy Y for running live mobile. only i create in the device a "portable wifi zone" (in the conection setting) and DONE!! If you want you can put a password (for a private conection).
I use this for connect an ipad and a galaxy using live mobile with the software.... works great!!!!
I am using a tmobile hotspot. I run the mobile app for focusing in, saves running back & forth.
