I got a problem.
Im programming my heads in the generaot. Playback goes well.
When i generate the selected, it fails in normal playback.
How is that?
generator > generate > fail playback?
MickeyMick
- house hardstyle.rar
- here is the gen file, generate it and see what happens :(
- (694 Bytes) Downloaded 1454 times
Re: generator > generate > fail playback?
In order to have a chance to help you, we need to understand the problem.
Please give us more details.
MickeyMick
Step 1. I open the gen.
step 2. i open the file ive been sending u
step 3. ill play the file in the gen to see what it does
step 4. generate it to a scene.
step 5. playback in normal mode (not the generator)
step 6. it fails to playback my scene. Only 1 head moves and it doesnt look like my scene in the generator
See my gen file to see what i have done.
short summary:
Heads move in a circle, and the lights go on and off with the dimmer.
i made a pattern like this: UUUUU but upside down. so the go on off on off on off very fast
It works in the gen so why wouldnt it work in normal playback?
short summary:
MickeyMick
o and please hurry. I need the scenes tomorrow :O
Only 1 light works in playback mode (normal mode) but in the gen both work. So no problems with the light.
You posted only one file.
We need the complete lightshow.
Please post the complete lightshow.
Any news on this because I had the same problem yesterday!
No need to upload shows just test it with 6 moving heads patched in Editor, open generator, make a circle and push Play, now you see it runs fine in a good loop. Now generate this circle to Editor and play it from there and you'll see .... Problem.... no seamless loop anymore....
Help is wanted
Help is wanted
Please read this: viewtopic.php?f=11&t=551
This might be the problem.
