UDP to MIDI
Posted: 16 April 2020, 12:55
by cmgmbh
Does anybody know a way / software / interface that can convert UDP commands to MIDI commands - for example to control / start the lights by an external device that sends an UDP command when it is triggered?
Re: UDP to MIDI
Posted: 21 April 2020, 09:34
by thorehl
External device or same computer?
Re: UDP to MIDI
Posted: 21 April 2020, 11:54
by cmgmbh
thorehl wrote:External device or same computer?
The UDP command will be from an external device (i.e. Brightsign player). Imagine that this external device is triggered and then it should send an UDP command (or any other protocol / solution) to the computer and the computer should interpret it as a MIDI command to trigger a scene / timeline in QuickDMX.
Re: UDP to MIDI
Posted: 22 April 2020, 08:38
by Niffo
You can trigger a live scene in the software using this TCP protocol :
https://forum.thelightingcontroller.com/viewt ... =72&t=4183
