UDP to MIDI
cmgmbh
UDP to MIDI
Post by cmgmbh »
Does anybody know a way / software / interface that can convert UDP commands to MIDI commands - for example to control / start the lights by an external device that sends an UDP command when it is triggered?
thorehl
Re: UDP to MIDI
Post by thorehl »
External device or same computer?
Thore
Using HW: D1024 & D512
Controller: 2x Akai APC mini
my DIY light mixer
cmgmbh
Re: UDP to MIDI
Post by cmgmbh »
thorehl wrote:External device or same computer?
The UDP command will be from an external device (i.e. Brightsign player). Imagine that this external device is triggered and then it should send an UDP command (or any other protocol / solution) to the computer and the computer should interpret it as a MIDI command to trigger a scene / timeline in QuickDMX.
Re: UDP to MIDI
You can trigger a live scene in the software using this TCP protocol : https://forum.thelightingcontroller.com ... =72&t=4183
