Error message "There is no page to show" [fixed]
doudoupf
Post by doudoupf »
Hi
i have a problem .
i have a iphone 4 and a box SweetlightBox (metal casing box with 4 plastic feet)
I want to control my box with my iphone .
i have set up the setting which i have found on the forum
My ip adress of my Pc is 192.168.0.20
i have set up this adress to control board .
And i do a DMZ on my routeur to my PC at my ip adress 192.168.0.20
I have desactived the firewall .
the error message is : there are no page to show
Thank to help me
best regards
Live_Mobile
- open the Settings of the iPhone
- select "Live_Mobile"
- Live IP address: enter the IP address of the computer where is our software
- Live port: keep the port value to 7348, which is the default value in the software
- Live password: enter a 4 digits password ("1234" for instance)
- connect your smartphone to the wifi network
Firewall (on computer)
Make sure your firewall is not blocking TCP communication via port 7348
Software (on computer)
- check the option Live > Preferences > Allow Live_Mobile (and restart Live)
- enter the same password in Live > Preferences > Live_Mobile password
- for each page you want to see in Live_Mobile, check the option Live > Page (right click) > Visible in Live_mobile
Re: Impossible to connect my iphone to my box
Are you sure you followed the last line of the tutorial ?
rbekel
Post by rbekel »
I have the same problem iphone will not connect to ShowXpress. I have followed the instructions many many times and it will not connect. It will not connect even if I turn off the firewall. With firewall off it continually keeps trying to connect but does no. With the firewall turned on, it tries to connect and then shortly thereafter says it cannot connect and asks if I want to try again. H E L P!!!
Re: Error message "There is no page to show" [fixed]
In this topic, the iphone connects perfectly to the computer.
The problem is there was no pages in Live with the option "Visible in Live_Mobile".
After checking this option to at least one page in Live, it worked.
You problem is totally different.
Please do not post in different problems topics.
rbekel
Post by rbekel »
Where can I post the problem then?
Create a new topic in this section: viewforum.php?f=48
Return to “General”
