Adding DMX universes without using a usb box [fixed]
thechrismartin
Post by thechrismartin »
Hi I am a Lighting designer out of Nashville that is working for other people in other states. Most of the time, I get room dimensions and fixture types, create a show file, and then email it to them. That being said, I do not have a usb box YET. I need to be able to add multiple universes in my visualizer. Is there a way to do this? I see the options in my patch window, but they are unable to be selected. Thank you.
Chris Martin
2 Sound Productions
Nashville, TN
Re: Adding DMX universes without using a usb box
This is possible.
Select the quantity of universes here: ControlBoard > Settings > Other > Quantity of universes
In Setup, use "U1", "U2", ... to address fixtures in different universes.
thechrismartin
Re: Adding DMX universes without using a usb box [fixed]
thank you.
Return to “Setup”
