Fader vs. preset slider in a button.
Luces
Post by Luces »
When I made a button for a scene with several steps, the moving heads don't follow the precise path if I use the fader slider, but only when using the preset slider. Is there a way to make the fader slider be more precise, like the preset slider? It's so much easier to use the fader slider.
Related to this; can I map this button to a fader in the Akai midi controller so that it's precise in the movements of the moving heads, just like the steps in the recorded scene? I'm attaching a video below.
Thank you.
https://drive.google.com/file/d/1scUk3a ... sp=sharing
Re: Fader vs. preset slider in a button.
The "fader slider" fades the channels from first to last step in a linear way.
It does not consider the middle steps.
Sorry for that.
Luces
Post by Luces »
Makes sense. I wanted to give an update on using the midi controller Akai APC mini to control to moving heads on a set circular path. It works well for my needs. If you make the button have a PRESET SLIDER, and assign that button to a fader, you can control two moving heads following a set path pretty well, back and forth. A trick to use it even better, is to hit the button and then use the fader; this prevents the lights to go off when the slider reaches the beginning position.
Regards.
Thank your very much for this tip :-)
