Moved a fixture to a separate universe [fixed]
Hello all. The other day I was messing around with stuff and moved a fixture to a second universe. The problem being I do not have a second universe... So now I have lost control of that fixture... Is there any way to get it back into my primary universe??
Re: Moved a fixture to a separate universe
Yes, here is how to proceed:
- in the module Fixtures, select the other universes (from "2" to "6" above the 2D view), until you see your lost fixture
- right click on the lost fixture and select the popup menu "Change universe"
- enter the number "1" for first universe and press "ok"
In case of you are not able to select the other universes above the 2D view:
- open the main menu "File" and select "Preferences"
- in the window "Preferences" in the tab "Main", select "Quantity of Universes" = 6 and press "Apply"
Then you could select the other universes above the 2D view.
Re: Moved a fixture to a separate universe [fixed]
Got it! Thank you!!
