Shared Channels limited to 30
lundtn
Post by lundtn »
I'm wondering if there is a way that I'm not aware of to go beyond channel 30 for shared channels in Pixels. For instance the ADJ UBL12H has the dimmer and shutter controls on channels 40 and 41. I know I can workaround with a steps scene that has the dimmers and shutters open and macro them but it would be nice if that feature was packed into the pixels world.
Re: Shared Channels
This is presently not possible from the software to declare more than 30.
But it looks (first try so not tested a lot) this is possible by manually modifying a file in your lightshow:
- edit the file "../YourLightshow/Pixels/fixtures.ini"
- find the line "FirstChannels = 0|0|0..." and add some "0|" until to have 40 of them
PS: problem noted.
Return to “Pixels”
