J-Maz - FX 5050 bar
ask here the fixture profile you need for Pixels
Ssawahl
J-Maz - FX 5050 bar
Post by Ssawahl »
I have a few J-MAZ Pixel FX 5050 bars I would like to try to creat pixel effects with but the fixture profile does not appear in the Pixels folder. Does a profile for these exist?
Thank you
Re: J-MAZ fixture profile for Pixels
Please provide a link to download the manual of this DMX fixture and we will do the profile for you.
FYI: https://forum.thelightingcontroller.com ... f=3&t=2453
Alternatively, you can also do the profile by yourself in the module "Pixels".
Ssawahl
Re: J-Maz - FX 5050 bar
Post by Ssawahl »
https://www.americanmusical.com/media/m ... maUcxAR0er
And I'm using the the bar as 18 channels
Thank you
The 18 channels mode is not suitable for our module "Pixels" because it does not have individual pixel control.
And our software can manage RGB, RGBW or W (white) pixels, but it is more sensible with several white pixels followed by several RGB pixels.
So we propose to use the mode 61 channels and to make two fixtures:
- one with channel #3 to #12 for the white pixels
- one with channels #33 to #56 for the RGB pixels
Please let us know.
Ssawahl
Post by Ssawahl »
Oh ok thank you. Sadly I will not be able to add them that way they would take up too many spots in my setup.
Thank you.
Ssawahl
Post by Ssawahl »
Good afternoon I finally was able to upgrade to the Xpress 1024w so now I can set up the 5050 bars in 61 channel mode but when adding the fixture to pixels the shared channels only go up to 30 the RGB LEDs are channels 33 through 56 as you mentioned in an earlier reply. How do I create this?
We took some time to first try to understand how it works, hoping to find some solutions with our module "Pixels" to mke some Pixels programs, but we are still lost with this fixture.
We finally suggest to make a profile for Editor (not Pixels) and call the internal auto programs.
If you are ok with that, we will make the profile for Editor. We suggest the 18 channels model.
Ssawahl
Post by Ssawahl »
I already use the bars in the 18 channel mode, I was hoping to get more control over the bar. I guess I'll keep trying to play around with it..
Return to “Fixture profile requirement for Pixels”
