Speed Label Under Button Trigger [fixed]
muscanto
Post by muscanto »
Can you update the drop down menu for speed fader source to pull in the custom fader name that i've used for the faders?
Speed Label.png (116.01 KiB) Viewed 28962 times
Re: Speed Label Under Button Trigger
Done for next fix file.
Please note that the master fader associated with the button continues to be indexed by number. So if you rearrange your master faders, you will still need to manually update the master fader speed associated with the button.
muscanto
Post by muscanto »
I have noticed that. It's kind of unfortunate. If I have to add a fader, I have to go through the entire lightshow and find all buttons that have assigned values for speed and correct them. Is there not a good solution for that?
Not in a simple way. Maybe in a future major version.
muscanto
Post by muscanto »
Thanks for the quick fix.
The name of the Master fader speed is visible in the new version 9.4.00.
