Hallo =)
ich habe folgendes Problem. ich bekomme das Artnet nicht zum funktionieren.
Die Anleitungen hier im Forum habe ich alle befolgt und ausprobiert.
System:
-Win 10 pro.
-QuickDMX 9.3.21 x64
-D1024 Interface ( 2Universen Aktiv, 1x Artnet (electroconcept Node1) soll als Universum 3 dazu.)
ich weis leider nicht weiter und hoffe jemand kann mir helfen wo das problem liegt.
Google Translate :/
Hello =)
I have the following problem. I can't get ArtNet to work.
I've followed and tried all the instructions here in the forum.
System:
-Win 10 Pro.
-D1024 interface (2 universes active, 1x ArtNet (electroconcept Node1) should be added as universe 3.)
Unfortunately, I don't know what to do and hope someone can help me figure out what the problem is.
thanks a lot
AN on Win10 QDMX won´t work [fixed]
- Node.JPG (95.47 KiB) Viewed 87334 times
- Netzwerk.JPG (36.42 KiB) Viewed 87334 times
- Ipv4.JPG (125.48 KiB) Viewed 87334 times
Re: AN on Win10 QDMX won´t work
You have to set the Artnet IP of your device (2.0.0.1 ?) in the "Fixtures" module of the software too.
hi
Yes ! in the Fixture module i have set the IP to the Fixture 2.0.0.1
But I just read that the D1024 can only handle 2x 512 channels
or 1x 512 + 512 ArtNet channels.
That surprises me a lot!
QDMX tells me: 2 universes found
and
3 ArtNet channels available
in the start screen
but does that mean I can't operate 3 universes?
and
in the start screen
D1024 allows 2 DMX universes and three ArtNet universes (starting from the first universe). So the first two universes are common between DMX and Artnet and the third universe is exclusively ArtNet.
Okay,
so that means that universes 1 and 2 are running with 512 channels each. Plus the third universe via Artnet with 512 channels. So 1536 channels on three universes at the same time. Right?
Hi, and thank you so much for the help.
... I've already solved the problems with Artnet... it was my own stupidity. I forgot or didn't see that I had to configure the universe in the node. But it's logical! I'm always learning something new. XD
Re: AN on Win10 QDMX won´t work [fixed]
Good news !
Thank you for the feedback.
