Fan group of fixtures
create lighting scenes
Savelim
Post by Savelim »
is it posible to fan a group of fixtures.
by pressing a butten or holding down the shift button?
when i have 16 movingheads or scan's i want to make a fan all over the stage. it makes a nicer look.
Thank you.
tomrbland
Re: Fan group of fixtures
Post by tomrbland »
I have been trying to get this feature implemented for years! No, at the moment you can't.
Savelim
Post by Savelim »
i hope they will be added in the software.
i think that many people wold like this.
andrews99
Post by andrews99 »
Are you referring to Phasing?? A delay between fixture movement? I am trying to do this as well
"delay between fixture movement" is possible with program Generator.
tomrbland
Post by tomrbland »
The delay is possible - when the fixtures are moving a delay is inserted between each fixture, in this software it is called "Fan". What was being requested here was the ability to do the same thing but when the lights are static. Ie starting with a bunch of moving heads pointing straight forwards and then being able to "fan" them out, or in. Exactly as it would look if your froze a generated scene. Another example would be a row of par cans if you turned them all up to full brightness and then "fanned them" you might be able to get them looking like: 0% 20% 40% 60% 80% 100% 80% 60% 40% 20% 0% without having to spend ages doing it manually.
andrews99
Post by andrews99 »
Got it thanks for your response.....
Return to “Editor”
