copy/past scenes OR values from one dimmer to another [fixed]
create scenes with steps
Hey_Mister_DJ
Post by Hey_Mister_DJ »
I have Showxpress but limited knowledge.
I have scenes for a couple Chauvet Intimidator 450 moving heads that ideally I want to transfer over to 2 new moving heads (same brand/model)
I have 2 of them and each is on a different DMX address.
Created seperate scenes for color, movement and Zoom.
Now, I added 2 more units (seperate DMX address for each) and I created a seperate TAB for control.
So Tab one is for movers 1 & 2 then I created a new tab to control movers 3 & 4.
Question-
Is there an easy way to copy/past the scenes for movers 1 & 2 (tab one) over to movers 3 & 4 (tab two)?
I created a new folder in the C Drive/lighting controller/scenes
I understand I can open the scene from mover 1 & 2, then click EDIT and manually add movers 3 & 4 but then have to recreate all the fader assignment which will be tedious.
Or, question #2- if I do the above process, is there a way to copy the data from one fader and paste it onto another to speed up the process?
Thanks in advance for your help!
Re: Is there a way to copy/past scenes OR values from one dimmer to another?
It is possible to copy all steps of a fixture to another one with a few mouse clicks.
We just made this small video to explain: https://youtu.be/B0IJGjD_ZxA
Return to “Editor - Steps”
