Intimidator spot 375zx not moving [fixed]
when am editing some scenes I want to visualize on the 3d viwer but fixture remain on the same position even though im movin the sliders up and down it doesnt do anything. the other spotlights that I have works as they should be on the 3d viewer. any idea why is this happening. only with this moving head.
Re: 3d viwer intimidator spot 375xz
There are some error with its profile (sorry for that).
Please replace the file by the attached one (15 or 9 channels), and this will work better.
- Intimidator Spot 375ZX (9CH).txt
- (2.66 KiB) Downloaded 5083 times
- Intimidator Spot 375ZX (15CH).txt
- (2.66 KiB) Downloaded 5120 times
Re: Problem with Intimidator spot 375zx
THANK YOU!! PROBLEM SOLVED/
Re: Intimidator spot 375zx not moving [fixed]
Good news !
Thank you for the feedback.
hello I recently bought a new laptop apple m4
I installed show xpress back into the new laptop but the chauvet intimidator 375zx profile isn't working.
it doesn't show colors just white
Did you also replace the library with the above file ?
