Channel Limit for Tilt
Urs
Post by Urs »
Is there a way to set a channel limit and minimum, for example in a fixure or in a step scene? I have moving heads that can make 270 degree tilt movements. But I would like them to only be able to do 90 degrees, for example, starting at 90 degrees. (The degree numbers are just an example). I have tried the offset setting, but it is only possible to adjust one side.
Re: Channel Limit for Tilt
This is not possible in this version of our software (V9) ; sorry for that.
And this is possible in our new software (VII BETA version).
https://www.youtube.com/watch?v=8rT-iv1Z1UM
https://forum2.thelightingcontroller.co ... ic.php?t=7
6ko
Post by 6ko »
You can play with zoom in the same windows as offset.
Negative zoom will reduce max amplitude, offset will define min amplitude.
Return to “Editor - Fixtures”
