Hi dear,
Work the software in the live buttons with the elgato streamdeck xl?
stream deck xl
Re: stream deck xl
We found only the "quick start" guide of this device which does not have all technical infos.
Could you please point us to the technical manual of this device ?
Re: stream deck xl
On MacOS they use "Companion". I don't know if it exists for Windows.
Re: stream deck xl
Yes, Companion is available for Windows
You can use Companion to send MIDI commands from the StreamDeck XL to The Lighting Controller. I believe there are other users on this forum who are deploying this solution
Re: stream deck xl
Oke. With Companion for windows it is possible to activate and deactivate with the stream deck xl the live buttons in Quick DMX if i understand it right?
How do it works?
How do it works?
Re: stream deck xl
I found the same, only quick manual
Re: stream deck xl
I’ve been using it for a year so far and it works. Only complaint and I’m not sure if it’s companion, showxpress, or the computer, but when I activate companion for showxpress my showxpress lags majorly. When I disable the companion just for showxpress it moves along just fine.
I’m using the Streamdeck + and have to use the midi plugin to control the master faders but it does work.
Re: stream deck xl
Noted.
We will check that asap.
BTW, your profile says you are using Windows. If not, please let us know.
