Closing Application not responding [fixed]
1314shaun
Post by 1314shaun »
Hello.
When closing the program/application on both of my windows laptops it seems to freeze and it says on the top bar (Not Responding) then i have to force close it.
Any ideas? This is happens on both closing options (file - quit) and also the top right hand red X quit button.
Many thanks
Re: Closing Application not responding
Please try with an empty loaded lightshow, and let us know if same.
Check also you are using version 9.3.8 or later.
1314shaun
Post by 1314shaun »
With an empty lightshow it closes perfectly.
Im not sure where to find what version i am using. I downloaded it from here last week.
Please advise how i can find the problem.
Please post a wetransfer link to download your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168). We will check that.
To open the small window showing the version of the software: main menu > Help > About
1314shaun
Post by 1314shaun »
Version 9.3.8. lightshow emailed over. thanks!
Your zip file contains only three ini files and one log file.
We need the complete lightshow. Please follow this: https://forum.thelightingcontroller.com ... ?f=3&t=168
1314shaun
Post by 1314shaun »
Resent. Thanks!
We are able to reproduce the problem with your lightshow.
We will work on that asap.
Fixed for the next fix file
1314shaun
Post by 1314shaun »
Ok thank you. Is there anything i need to do now?
Thanks!
