Generator/Editor shut's down [done]
create lighting scenes
eisendrath
Post by eisendrath »
Since this weekend I have a problem with the generator. I start the editor, choose my group moving heads (2 indigo show tech 150led), then choose the generator symbol everything is running well. I choose the channel Pan/Tilt: still working. Then I choose a 2nd channel like dimmer, the generator shuts down and this message occures: editor.exe does not working anymore.
Had you this problem before?
Alexander
Re: Generator/Editor shut's down
May be, for an unknown reason, the lightshow is corrupted.
Can you send us your lightshow, and specify the exact procedure to get this problem ?
We will check this.
eisendrath
Here's the procedure: Open Sweet Light Controller, choose Editor, choose Group, choose Indigo, go to generator, choose pan tilt, choose, dimmer or shutter.
I solved the problem with copying a back up of the latest know lightshow-version. attached you find my lightshow when it was corrupted.
We did not receive your "corrupted" lightshow.
Could you please re-send it ?
Return to “Editor”
