Eliminator - Frost FX Bar RGBW (111ch)
ask here the fixture profile you need for Pixels
toddmoses34
Post by toddmoses34 »
Anyone have a profile for Eliminator Lighting Frost FX Bar RGBW? I've created a functional 18 channel profile but would like
the full 111 channel profile to gain full control because the 18 channel is limited to auto programs. Thanks in advance.
Re: Eliminator Lighting Frost FX Bar RGBW 111 Channel
Please give us a link to download the manual of this fixture and we will do the profile for you (https://forum.thelightingcontroller.com ... f=3&t=2453).
toddmoses34
Sorry. I should have included the traits. Thanks for your help.
https://d295jznhem2tn9.cloudfront.net/I ... TRAITS.pdf
Done, but please read carefully below:
This fixture is a bit complicated, as it's got basically two different Pixel fixtures within it. One set of 14 RGBW "main" pixels, and one set of 14 RGB "Background colour" pixels. Since Pixels can't handle this natively in one head file, we did a workaround by splitting up the head into two files, one for each set of pixels respectively. So you would just need to patch both files in, and offset the second file by 57 channels. It's not perfect, but it will work.
Return to “Fixture profile requirement for Pixels”
