Dear Forum Members
I have the Elaton Midicon2 in use, together with ShowXpress. I would like to use the fader pages on the Midicon to use more than 8 faders. How can I configure this? Can I do it directly in ShowXpress or do I need the Midi Mapper software? Unfortunately it did not work with the learning button. The page is ignored.
Midicon2 - how to change page ?
Luc Henrion
Re: Midicon2 and ShowXpress
Looking at the Elation manual, it doesn't seem that the fader pages send a MIDI message... This is an issue you should submit to Elation.
According to Elation the whole fader bank should get a new midi address when changing the page. I will now check the firmware.
Our software is able to return a midi message only after receiving one.
Sorry for that.
Sorry for that.
The problem is solved.
With the Midi Mapper software from ADJ Midicon the paping can be enabled. After that process everything works fine.
Regards
Urs
Regards
Urs
- MidiMapper_Screenshot.png (57.9 KiB) Viewed 6548 times
