Monterey - Show express
Ray825
Post by Ray825 »
Trying to run show express with my Mac using Monterey. It was working fine then stop. I removed the program and downloaded again. Now when I try to bring a fixture in it crashes. Anyone have any advice with this issue ?
Re: Monterey - Show express
There may be a corrupted file in your lightshow (?)
Please post a ZIP to download your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168). We will check it.
Ray825
Post by Ray825 »
It crashes when I try to load a fixture so I can't get as far as creating a light show. I pasted below error message.
Translated Report (Full Report Below)
Process: TheLightingController [1585]
Path: /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-07-20 15:57:49.5120 -0400
OS Version: macOS 12.4 (21F79)
Report Version: 12
Bridge OS Version: 6.5 (19P5071)
Anonymous UUID: CB6679A9-F4BD-8DA0-AD6B-16A571655F5B
Sleep/Wake UUID: 49ACCFE5-1901-4A70-967E-48D19C5E13F9
Time Awake Since Boot: 26000 seconds
Time Since Wake: 11458 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
Exception Codes: 0x0000000000000001, 0x0000000000000028
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1585]
VM Region Info: 0x28 is not in any region. Bytes before following region: 140737487101912
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x/r-x SM=ALI
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 TheLightingController 0x1000e0dc1 0x100000000 + 921025
Thread 1:
0 libsystem_pthread.dylib 0x7ff8190b3f48 start_wqthread + 0
Thread 2:
0 libsystem_kernel.dylib 0x7ff81907e2be __semwait_signal + 10
1 libsystem_c.dylib 0x7ff818f92863 nanosleep + 196
2 TheLightingController 0x1001a0ab7 0x100000000 + 1706679
3 TheLightingController 0x1000ae494 0x100000000 + 713876
Thread 3:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff81907b97a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff81907bce8 mach_msg + 56
2 CoreFoundation 0x7ff81917f38d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff81917da18 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff81917ce5c CFRunLoopRunSpecific + 562
5 AppKit 0x7ff81bd29c1e _NSEventThread + 132
6 libsystem_pthread.dylib 0x7ff8190b84e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff8190b3f6b thread_start + 15
Thread 4:
3 TheLightingController 0x10013074f 0x100000000 + 1247055
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000100001b60 rcx: 0x0000000000000200 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x0000000000000000 rsp: 0x00007ff7bfeff7f0
r8: 0x0000600002c0bae0 r9: 0x0000000000000000 r10: 0x00000001002d2f60 r11: 0x00007ff81bbf2877
r12: 0x00007ff85a8384e0 r13: 0x00000001003b7680 r14: 0x0000000000000000 r15: 0x0000000000000001
rip: 0x00000001000e0dc1 rfl: 0x0000000000010202 cr2: 0x0000000000000028
Logical CPU: 6
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
48 8d 2d a0 1b 2a 00 48-0f b6 45 23 49 39 c7 0f H.-..*.H..E#I9..
85 cf 1f 00 00 48 8b 2d-c7 25 2a 00 4c 0f bf 7d .....H.-.%*.L..}
30 4c 0f bf 75 30 49 ff-ce 4c 89 f0 48 89 c0 50 0L..u0I..L..H..P
5f e8 67 8d 07 00 49 89-c6 49 ff ce 49 c1 e6 09 _.g...I..I..I...
4d 29 f7 4c 89 bc 24 b0-00 00 00 4c 8b bc 24 b0 M).L..$....L..$.
00 00 00 48 8b 2d 89 25-2a 00 48 8b 6d 28 55 58 ...H.-.%*.H.m(UX
[ff]75 28 5f e8 66 a9 0d-00 49 01 c7 4c 89 bc 24 .u(_.f...I..L..$ <==
b8 00 00 00 4c 8b bc 24-b0 00 00 00 49 ff cf 4c ....L..$....I..L
89 f8 48 c7 c1 20 00 00-00 48 99 48 f7 f9 49 89 ..H.. ...H.H..I.
c7 4c 89 bc 24 c0 00 00-00 4c 8b bc 24 b8 00 00 .L..$....L..$...
00 49 ff cf 4c 89 f8 48-c7 c1 20 00 00 00 48 99 .I..L..H.. ...H.
48 f7 f9 49 89 c7 4c 89-bc 24 c8 00 00 00 4c 8b H..I..L..$....L.
Binary Images:
0x100000000 - 0x1002bbfff TheLightingController (*) <b01c0629-6aa2-3c78-a210-8e3b6420fcab> /Volumes/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x7ff8190b2000 - 0x7ff8190bdfff libsystem_pthread.dylib (*) <bc574849-1aae-31e7-b350-916dda999d97> /usr/lib/system/libsystem_pthread.dylib
0x7ff81907a000 - 0x7ff8190b1fff libsystem_kernel.dylib (*) <61711d11-e776-3bc3-b9a2-6f9f37cb8499> /usr/lib/system/libsystem_kernel.dylib
0x7ff818f82000 - 0x7ff81900afff libsystem_c.dylib (*) <d9ba0660-744d-3f84-9f80-afb51d450512> /usr/lib/system/libsystem_c.dylib
0x7ff8190ff000 - 0x7ff819601fff com.apple.CoreFoundation (6.9) <f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81bb7d000 - 0x7ff81ca0bfff com.apple.AppKit (6.9) <832ad371-d3b8-3061-b4e2-1c4e0cffce0b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=961.0M resident=0K(0%) swapped_out_or_unallocated=961.0M(100%)
Writable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 640K 5
Activity Tracing 256K 1
CG backing stores 2880K 4
CG image 32.5M 124
ColorSync 224K 26
CoreAnimation 111.1M 130
CoreGraphics 12K 2
CoreUI image data 2972K 24
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 318.2M 66
MALLOC guard page 48K 10
MALLOC_MEDIUM (reserved) 944.0M 8 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
ObjC additional data 15K 1
STACK GUARD 56.0M 12
Stack 15.1M 12
VM_ALLOCATE 18.7M 100
__CTF 756 1
__DATA 21.4M 369
__DATA_CONST 19.1M 223
__DATA_DIRTY 913K 134
__FONT_DATA 4K 1
__LINKEDIT 648.2M 10
__TEXT 312.8M 387
__UNICODE 592K 1
dyld private memory 1024K 1
mapped file 144.2M 21
shared memory 784K 17
TOTAL 3.0G 1693
TOTAL, minus reserved VM space 1.7G 1693
Full Report
{"app_name":"TheLightingController","timestamp":"2022-07-20 15:57:51.00 -0400","app_version":"","slice_uuid":"b01c0629-6aa2-3c78-a210-8e3b6420fcab","build_version":"0.1","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 12.4 (21F79)","incident_id":"73F208ED-F455-43F9-B132-D39A2458B92E","name":"TheLightingController"}
"uptime" : 26000,
"procLaunch" : "2022-07-20 15:57:20.0582 -0400",
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Macmini8,1",
"procStartAbsTime" : 26749847751187,
"coalitionID" : 1832,
"osVersion" : {
"train" : "macOS 12.4",
"build" : "21F79",
"releaseType" : "User"
"captureTime" : "2022-07-20 15:57:49.5120 -0400",
"incident" : "73F208ED-F455-43F9-B132-D39A2458B92E",
"bug_type" : "309",
"pid" : 1585,
"procExitAbsTime" : 26779301836977,
"cpuType" : "X86-64",
"procName" : "TheLightingController",
"procPath" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"bundleInfo" : {"CFBundleVersion":"0.1"},
"parentProc" : "launchd",
"parentPid" : 1,
"crashReporterKey" : "CB6679A9-F4BD-8DA0-AD6B-16A571655F5B",
"wakeTime" : 11458,
"bridgeVersion" : {"build":"19P5071","train":"6.5"},
"sleepWakeUUID" : "49ACCFE5-1901-4A70-967E-48D19C5E13F9",
"sip" : "enabled",
"vmRegionInfo" : "0x28 is not in any region. Bytes before following region: 140737487101912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x\/r-x SM=ALI ",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x0000000000000028","rawCodes":[1,40],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000028"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1585},
"vmregioninfo" : "0x28 is not in any region. Bytes before following region: 140737487101912\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n VM_ALLOCATE 7fffffece000-7fffffecf000 [ 4K] r-x\/r-x SM=ALI ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":143785,"instructionState":{"instructionStream":{"bytes":[72,141,45,160,27,42,0,72,15,182,69,35,73,57,199,15,133,207,31,0,0,72,139,45,199,37,42,0,76,15,191,125,48,76,15,191,117,48,73,255,206,76,137,240,72,137,192,80,95,232,103,141,7,0,73,137,198,73,255,206,73,193,230,9,77,41,247,76,137,188,36,176,0,0,0,76,139,188,36,176,0,0,0,72,139,45,137,37,42,0,72,139,109,40,85,88,255,117,40,95,232,102,169,13,0,73,1,199,76,137,188,36,184,0,0,0,76,139,188,36,176,0,0,0,73,255,207,76,137,248,72,199,193,32,0,0,0,72,153,72,247,249,73,137,199,76,137,188,36,192,0,0,0,76,139,188,36,184,0,0,0,73,255,207,76,137,248,72,199,193,32,0,0,0,72,153,72,247,249,73,137,199,76,137,188,36,200,0,0,0,76,139],"offset":96}},"threadState":{"r13":{"value":4298864256},"rax":{"value":0},"rflags":{"value":66050},"cpu":{"value":6},"r14":{"value":0},"rsi":{"value":0},"r8":{"value":105553162451680},"cr2":{"value":40},"rdx":{"value":0},"r10":{"value":4297928544},"r9":{"value":0},"r15":{"value":1},"rbx":{"value":4294974304},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":140703594129527,"symbolLocation":0,"symbol":"-[NSView frame]"},"rip":{"value":4295888321,"matchesCrashFrame":1},"rbp":{"value":0},"rsp":{"value":140702053824496},"r12":{"value":140704647185632,"symbolLocation":0,"symbol":"dyld4::gDyld"},"rcx":{"value":512},"flavor":"x86_THREAD_STATE","rdi":{"value":0}},"queue":"com.apple.main-thread","frames":[{"imageOffset":921025,"imageIndex":0}]},{"id":143819,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":143828,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":713876,"imageIndex":0}]},{"id":143834,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":2},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":2},{"imageOffset":525197,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":4},{"imageOffset":518680,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":4},{"imageOffset":515676,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":4},{"imageOffset":1756190,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":5},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":1},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":1}]},{"id":143849,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":1247055,"imageIndex":0}]},{"id":143851,"frames":[{"imageOffset":17086,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":2},{"imageOffset":67683,"symbol":"nanosleep","symbolLocation":196,"imageIndex":3},{"imageOffset":1706679,"imageIndex":0},{"imageOffset":1247055,"imageIndex":0}]},{"id":143853,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":143855,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144101,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144102,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144103,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]},{"id":144104,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":1}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4294967296,
"size" : 2867200,
"uuid" : "b01c0629-6aa2-3c78-a210-8e3b6420fcab",
"path" : "\/Volumes\/*\/TheLightingController.app\/Contents\/MacOS\/TheLightingController",
"name" : "TheLightingController",
"CFBundleVersion" : "0.1"
"source" : "P",
"arch" : "x86_64",
"base" : 140703548776448,
"size" : 49152,
"uuid" : "bc574849-1aae-31e7-b350-916dda999d97",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703548547072,
"size" : 229376,
"uuid" : "61711d11-e776-3bc3-b9a2-6f9f37cb8499",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703547531264,
"size" : 561152,
"uuid" : "d9ba0660-744d-3f84-9f80-afb51d450512",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703549091840,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 5255168,
"uuid" : "f8e45ef9-9fd2-3331-bb1b-703d5dacdaf1",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "1863"
"source" : "P",
"arch" : "x86_64",
"base" : 140703593648128,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 15265792,
"uuid" : "832ad371-d3b8-3061-b4e2-1c4e0cffce0b",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2113.50.132"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"sharedCache" : {
"base" : 140703545520128,
"size" : 15220686848,
"uuid" : "398acfb4-57f6-31e0-bc82-e9959e5c92ce"
"vmSummary" : "ReadOnly portion of Libraries: Total=961.0M resident=0K(0%) swapped_out_or_unallocated=961.0M(100%)\nWritable regions: Total=1.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.8G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 640K 5 \nActivity Tracing 256K 1 \nCG backing stores 2880K 4 \nCG image 32.5M 124 \nColorSync 224K 26 \nCoreAnimation 111.1M 130 \nCoreGraphics 12K 2 \nCoreUI image data 2972K 24 \nFoundation 16K 1 \nKernel Alloc Once 8K 1 \nMALLOC 318.2M 66 \nMALLOC guard page 48K 10 \nMALLOC_MEDIUM (reserved) 944.0M 8 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nObjC additional data 15K 1 \nSTACK GUARD 56.0M 12 \nStack 15.1M 12 \nVM_ALLOCATE 18.7M 100 \n__CTF 756 1 \n__DATA 21.4M 369 \n__DATA_CONST 19.1M 223 \n__DATA_DIRTY 913K 134 \n__FONT_DATA 4K 1 \n__LINKEDIT 648.2M 10 \n__TEXT 312.8M 387 \n__UNICODE 592K 1 \ndyld private memory 1024K 1 \nmapped file 144.2M 21 \nshared memory 784K 17 \n=========== ======= ======= \nTOTAL 3.0G 1693 \nTOTAL, minus reserved VM space 1.7G 1693 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"trialInfo" : {
"rollouts" : [
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000408
"rolloutId" : "60da5e84ab0ca017dace9abf",
"factorPackIds" : {
"deploymentId" : 240000008
"experiments" : [
Model: Macmini8,1, BootROM 1731.120.10.0.0 (iBridge: 19.16.15071.0.0,0), 6 processors, 6-Core Intel Core i7, 3.2 GHz, 64 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Display: onn. TV, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 32 GB, DDR4, 2667 MHz, 85F7, J644GU44J9266NQ
Memory Module: BANK 2/ChannelB-DIMM0, 32 GB, DDR4, 2667 MHz, 85F7, J644GU44J9266NQ
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: Wi-Fi, AirPort, en1
USB Device: Rugged USB-C
USB Device: PSSD T7
USB Device: USB31Bus
USB Device: StudioLive 32
USB Device: USB Receiver
USB Device: T2Bus
USB Device: Headset
USB Device: Apple T2 Controller
Thunderbolt Bus: Mac mini, Apple Inc., 47.5
Please try to rename or delete the folder "TheLightingController" in your "home directory".
Ray825
Post by Ray825 »
Thanks for the reply! I went inside the ShowXpress folder and found a file folder "Thelightingcontoller" and the one I normally click on to start the program same title. It wont let me rename or delete.
The folder "TheLightingController" to rename or delete is the one in your "home directory" ("Go" menu in the Finder then "Home")
Ray825
Post by Ray825 »
Thanks! I think that worked!
Return to “Mac OS”
